lg 42px5r no picture with sound
Re: lg 42px5r no picture with sound
By the way, do you cut the leads to the IPM or how do you do it, Favorite waywas thinking about desolder, is it possible
Never done it before, thankfully. The usual suggestion is to cut the leads with a side cutter, remove the module, then desolder the leads individually.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Hello nalle077,
I've been working on a 42PC3D, the sister model of your TV. It uses all the same parts except for the buffer, which is all one piece (instead of upper and lower). And my Y sus is a different form factor, (mine is 6870QYH002B) but is practically the same, just smaller heatsink than yours, and some components are rearranged.
My symptoms are EXACTLY the same: No picture, but there is sound; had 4 bad caps on the left side of the power board, I replaced them already. Still no picture.
I want to bring something to your attention about the IPM test you did.
Thanks.
I have measured according to the site and I found 1 thing that might be wrong. On my IPM (not the one on the picture I have 4921QP1027Q) there is no "ERout" I have "ER_I0", "ER_LOW", "ER_HIGH", "ER_DN" and "ER_UP" I have short between "ER_I0" and "SUS_OUT" and that is of course because I have it on the board ( if "ER_I0" and "ERout" is the same?) but I have 293 ohm between "+VS" and "ER_I0" if I have black probe on "+VS" and red probe on "ER_I0" the other way around I have almost Infinite.
What to think?
Does anyone have the same card and can see if it is the same on that?
If you set it to Mega Ohms (20M) on your dial you will get something like 2.930 Mega Ohms. The reading are the same, but with a decimal point after the first digit.
When I switch the probes with the dial set to continuity, I also get infinity.
I have the same IPM as your TV, the IPM model is YPPD-J018C/J017C. (check your label if you want to be sure).
Try the test again, with the dial on Mega Ohms.
My test results are like this AFTER I replaced my IPM
ER_UP to VSout @ 3.34 ~ 3.60 MegaOhms
ER_UP to GND @ 4.05 ~ 4.07 MegaOhms
ER_UP to SUS @ 0.00 MegaOhms (because its shorted on the board)
SUS to GND @ 2.28 MegaOhms
SUS to VSout @ 3.20 MegaOhms
GND to VSout @ 0.07 MegaOhms
They seem kind of low, especially the last one... makes me wonder if my solder joints weren't neat enough?
With the red probe on the fuse, and black on GND I get 14.04 Mega Ohm
Vice versa, black on fuse, red to GND gives a much lower 3.67 Mega Ohms
...Alas, I'm still hearing sound, but no picture.
Any comments are welcome.
I suspect the power board again.Comment
Hello Tom, good morning
Something terrible seems to have happened...but I'll answer your question first: Yes, I have checked all the voltages, and rechecked after I installed the new IPM.
The Ysus plug:
4.97v (5v)
0.00v (GND)
59.4v (Vo)
0.00v (GND)
0.00v (GND)
0.00v (GND)
0.00v (NC) <-- should this be at zero? what does NC stand for?
184.2v (VS)
184.2v (VS)
Now, on to the news. I got really excited today, because the TV actually had a PICTURE, and the backlight came ON for the first time. ...but my victory was short lived. I could hear a loud buzzing from my Z board.
I turned the set off, unplugged the Z board to make sure.
There was still buzzing! This time it was softer, coming from the Y board of course. I still saw a picture, with lots of mal discharge and black lines. So I tried to change the channel, then there was a loud CRACK, then 5 seconds later another "Crack", or pop if you will.
I turned the TV off, unplugged it and proceeded to check all the fuses assuming two had gone out. But all the fuses are showing 0 so they're closed.
And now the TV will NOT power up unless the Y board is disconnected, this sounds like my new IPM just got blown... Grrr!This seems to point again at the power board AND the Y board.
EDIT: I think I found a problem, the 10-pin connected to the main logic board. Yesterday, it had two 6v, now it only has one, I double checked just now. Or am I going mad?
Blue = 19.11v
Blue = 19.10v
Grey = 00.0v
Grey = 00.0v
Grey = 5.94v
Grey = 0.01v <- This one should have 6v too, right?
Grey = 3.37v
Grey = 0.00v <- and this one seems odd, it shouldn't read 0 either
Grey = 11.88v
Grey = 0.00vComment
--- begin sig file ---
--- end sig file ---Comment
On my TV Vs measured 194V and Va measured 60V. It's okay for it to be a bit low, you'll get a dimmer picture though. I usually set it a couple volts below nominal on LG plasmas, it gets rid of most sparklies and prolongs the life of the panel and sustain boards, and the change in brightness is barely noticeable. (Too low, and you'll get no picture, but most PSUs on these TVs won't output very low voltages.)
Blue = 19.11v
Blue = 19.10v
Grey = 00.0v
Grey = 00.0v
Grey = 5.94v
Grey = 3.37v
Grey = 11.88v
Grey = 0.00vPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
here are a picture on the back of my IPM on the board
IΒ΄ll be happy if anyone can tell me what is the same points on my IPMComment
Nalle I wish I knew. But I obviously made a mistake in assuming our IPMs were the same. Yours has 42 pins, mine has 32.
Yours looks like a YPPD-J009C, is that correct?
You have already tested ER_IO and SUS_OUT on your board and it was shorted (probably because it's shorted on your board outside of the module).
And my ER_UP and SUS was shorted. So maybe that's where you should start probing?
Yours = Mine
ER_IO = ER_UP
SUSout = SUS
Ah! Well, that's interesting... I got a 42PX5D from the local tip for Β£30. Plugged it in and the screen kinda glowed from the edges but then shut down so I immediately thought Z-sustain. I opened it up to find it had obviously been in a chain smoking home (or maybe a pub), as it was completely full of this awful brown dust. Cleaned some of the dust out and plugged it in. Screen lit up, but I hear this very loud buzzing, getting louder and louder over a couple of seconds until... CRACK, POP and a nice yellow spark from a MOSFET then it shut down. Uh oh, I thought the IPM had gone. Nope, it somehow managed to survive. The MOSFET had a bit too much dust on it and this was cleaned and it worked! As this TV has a fan I would check this before assuming the IPM was bad as the fan sucks in a *lot* of dust. My TV was completely clogged with it and I had the unfortunate job of inhaling a lot of it.Last edited by TechShui; 03-01-2012, 08:12 PM.Comment
No, it was just on the board. I think I got lucky that it didn't need replacing but it might need replacement. Post a pic of your board, I'll highlight it for you.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Best regardsComment
Here are the pictures of it. Please circle the mosfet that sparked on your set if you still remember.Comment
And I have a more general for anyone to comment on.
When I replaced the blown IPM in my Y-sustain, the heatsink compound was dry and powdery, -- no good. So I cleaned it all off of the heatsink and used some Arctic Ceramique instead of silicon-based compound. I assumed this would help tranfer the heat better.
In the 5 or so minutes that I had the TV on and working. I noticed the Y-sus heatsink was getting hot (hotter than normal) at the same time the buzzing was getting louder. This all means that something was drawing too much current, right?
Or did my Ceramique compound somehow cause the overheating? It should've helped the problem, not make it worse. I applied 4-5 long strips of paste,knowing that it would spread out when I screwed the heatsink back onto the ipm. I've applied thermal paste to CPUs dozens of times before, but again my question is whether the much cheaper silicon-based paste is better suited for IPMs?Comment
First time here to post, so dont think im trying to be the expert but I have repaired several of these same problems, but on different models...but it comes down to the same faulted part. the IPM, which controls the voltages and signals to the rest of the y-sus. The LG 42PC3D had several caps(10Vdc 3300uf) swelled, on the main power board that caused the IPM to blow. Taking the IPM off the y-sus is time consuming, but at 45 dollars for that part, and 12 for all the caps, is alot cheaper than having a 4-500 dollar repair bill. Dont go out and buy a used board, they might work for a little bit, but go bad and you be in the same mess again...thanks for listening...brianComment
UPDATE: Well, as it turns out, my Y-sus sparked and blew the IPM again, because of trace damage, the traces are pretty big, so I think I can repair them without much trouble.
The IPM can actually be bought for $30 from Coppell TVComment
Hi tom66, I want to see if you can help me to repair my Y-sustain. I am working on Samsung LJ92-01200A board which came from SANYO DP42746 Plasma tv.
Here is the link how to test IPM: http://blog.coppelltvrepair.com/2011_04_01_archive.html
It says any combination of these four connection must not be shorted. But when I checked ER and SUS they seem like shorted. But I think both SUS and ER is grounded. AS my x-sus has the same IPM and it acts the same way. My x-sus is good.
So I am kinda confused if my IPM is really bad or not. Please reply if you have any idea. Also the fuse near the IMP usually blows if the IPM is faultyLast edited by arman960; 09-20-2012, 09:34 PM.Comment
What did I tell you not to do?
https://www.badcaps.net/forum/showpo...7&postcount=40
I just answered your post in another thread and here I see it again.
If you want help from me in the future, STOP cross posting. Keep everything in one thread.--- begin sig file ---
Hello again.
I have been busy with moving and building so I have not been online for a while ( And have had no time for TV-repair)
I hate giving upso I really want this fixed.
Anyway I have changed the IPM and the problem is the same. TV starts but picture or backlight does not come on.
Any suggestions on what to do next ??Comment
Hello again.
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started βfading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly βnew' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
- Loading...
