Crosley LCD TV
  • db7am
    • Feb 2012
    Crosley LCD TV
    hi everyone
    first off i want to say 'thank you' to everyone that posts on here. its really helpful
    crosley flat screen tv doesn't turn on
    doesn't seem to be getting any power
    no lights no nothing
    model#c26hdbg
    26in
    does anyone have this tv?
    i can't even find a website for them...
    theres crosley.com but they don't even show tv's listed....weird
    thanks for reading!
    db
  • PlainBill
    • Feb 2009
    • 7034
    Re: Crosley LCD TV
    Crosley is a name that goes WAY back in the consumer electronics field.
    We treat these the same way we treat other, more common names with no literature available. First, remove the back of the TV. Take a single, sharp, well lit picture of the back of the TV. The picture should be close to, but not over 2000 pixels x 2000 pixels. This will help us identify the subassemblies, possibly spot any problems, and direct you to take additional pictures.
    PlainBill
    • bimole
      Weird behavior on 3.3V rail of a CORSAIR CX600
      by bimole
      A colleague gave me an apparently ill CORSAIR CX600.
      He told me that he heard a banging noise, and smelt the magic smoke.
      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
      It's another story on the 3.3V rail...
      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
      02-13-2025, 04:49 AM
    • MicroSMD Lab
      No display, Eluktro Pro (Clevo) P650HP6, board number 6-71-P65P0-D02A
      by MicroSMD Lab
      This laptop came in as no internal display. I did see it boot on an external monitor but it was not consistent, however, the bios splash screen was consistent. The customer said it happened after a windows update. I tested the display and there were no signals on the LED_EN or PWM test points. At this point I decided to treat it as a bios issue. I disconnected the RTC battery and drained the residual power. After this, I did not get the bios splash screen anymore. The power led changes colour, fans spin, GPU and CPU get warm and caps lock is functional. I tried the bios from the Clevo repo, there...
      05-09-2024, 12:35 PM
    • ohren
      by ohren
      09-08-2023, 05:24 PM
    • rotceh_dnih
      Removing coke or sugar syrup from liquid damaged devices.
      by rotceh_dnih
      Got an Xbox that had coke spilt in it, must not have been there long but it was sticky and my normal solvents were not making it budge so on a time budget I hit it with some Ajax spray and wipe glass cleaner and it brushed off within 20 seconds.
      Whatever's in that bottle is some nasty stuff but it worked a treat!
      P.S. I gave it ISO bath, ultrasonic then ISO bath again after these photos as I thought if it cleans up that well so fast it would very likely corrode if anything was left on the PCB....
      02-20-2023, 02:25 AM
    • pcconnect
      boardview and schematic for acer a715-42g LA-K831P
      by pcconnect
      hi guys, i've got this laptop with shorted board and no power and dont know where to start. i have basic knowledge about repair but treat me like a newbie
      thanks in advance
      09-08-2022, 03:10 AM
