Sanyo DP42545 no video, has sound . Ready to try some tests.
  • Jimmy Nolins
    • Feb 2012
    • 41
    Re: Sanyo DP42545 no video, has sound . Ready to try some tests.
    I have infrared thermometer , we use to check the heat in the tires of our drag car .. that should work , i'd think . let me go grab it from the shop .
    I'll check them , last time i left it on for a couple hours to see if it would show anythign different , and i am thinking nothing really had any heat to it. (when it was working this thing had heat for sure lol .
    • Jimmy Nolins
      • Feb 2012
      • 41
      Originally posted by rpgruss
      If you have a non-contact infrared thermometer, turn the TV on with everything connected. Give it a few minutes, check the temperatures on the Y and Z sustain board heatsinks. They should be warmer than room temperature. If one of them is room temperature then that is likely your defective board.
      turned it on for about 20 mins ( its in my garage , and its alittle nippy tonight ) heatsinks are 67 degrees and 68 degrees on other .. hummm
      • Jimmy Nolins
        • Feb 2012
        • 41
        Let me ask a couple more things. Should the Main board have temp in heatsinks since Va and VS was where it should be ? Is there any other voltage i need to check on the mainboard ?
        • Jimmy Nolins
          • Feb 2012
          • 41
          Removed the main board to check the dpd side , everthing looks good on backside . With my very litle testing knowledge all i can do is ask questions , so if the PDP itself is bad , would the heaksinks on all/ any of the other boards have some decent heat in them ?
          • cmj21973
            • 267
            Originally posted by Jimmy Nolins
            So i read some other posts again and thought at least let me check the y upper and y lower buffer boards . I recalled reading here about coppell blog and a write up they did. So i found it , but my buffer board connectors are different then the black ones shown . How do i test the style i have ?
            To test Y-Buffers:
            1) Disconnect the ribbon cables to the Y-buffers, circled "blue".
            2) Disconnect the connectors, between the Y-buffers and the Y-SUS, that look like the one circled in "green".
            3) Disconnect the Y-buffers from the Y-SUS by placing a flat screw driver between the PCB boards, near the connect outside end. Apply twisting pressure until it unseats a little. Move to the end of the connect and repeat.
            Continue this for the next connector. Go slow and gentle, until the connectors seperate.
            4) With the Y-buffers out, test one buffer at a time. Set DMM to continuity test, page 14 of Fluke 80 series III manual.
            5) Place one probe to any lead circled in "red" then slowly run the other probe down each side of the connect circled in "blue". Do this for the other connect, the one with the "red" circle.
            • Jimmy Nolins
              • Feb 2012
              • 41
              #26
              Thank you very much cmj21973 , I did this ( with beep feature on ) and got NO beep . I also check the backside of board to be sure and and no beeps . that was the UP board , i checked the LOW board ( pin layout is reversed for ground) also got NO beeps .
              So at this point it seems the Main board is showing correct voltage on VA and VS , and the buffers ( up/low ) seem to be good .
              • Jimmy Nolins
                • Feb 2012
                • 41
                #27
                I check the remaining voltages on the main board 12v , 33v 5v , ect. all came out fine . I removed a couple of the boards and checked the ceramic fuses all were good ...... I tried to enter service mode and nothing apppeared on the screen either
                Iam now wondering , since the kids were watching it when it went out , if somehow theysome how they managed to disable it from showing any video lol .... Is there a way to see if the pdp itself is bad ?
                  Does the screen glow, at all, in a dark room?
                  • Jimmy Nolins
                    • Feb 2012
                    • 41
                    #29
                    No , in a pitch black room when i turn power on i wouldn't even know it came on except for the green led under the screen.. and the sound .
                    • Jimmy Nolins
                      • Feb 2012
                      • 41
                      #30
                      Not giving up yet , So questions :
                      1) Should the Main board/ power supply board have heat roughly the same across the board with what my tv doing what its doing ? ( right side last heatsink staying 77 degrees ..... The Y main board heat sinks are 76 and 78 /// the x main heatsinks are 81 and 78 .
                      2) If the PDP is bad .. what else can i check to verify it is ? ( iam still thinking pdp board or logic) IF PDP is would there still be heat in the y and x main boards .
                      3) Any spots i should check on y and x board with DMM ?
                      Last edited by Jimmy Nolins; 02-17-2012, 02:12 PM. Reason: heat temps marked on board
                        Does either sustain buzz? Is the buzzing quite loud or about normal for a plasma TV? (Estimate it yourself...)
                        • Jimmy Nolins
                          • Feb 2012
                          • 41
                          #32
                          Not at all , i do hear a faint, very faint buzz from the main power board ( not audible if 10 to 12 inches away )
                          • Jimmy Nolins
                            • Feb 2012
                            • 41
                            #33
                            Also quick note , after removal of x and y board to recheck cables and see if i missed any bad caps , I reinstalled and now get a brief white light on the lower left side of panel , If that makes sense ..
                              That signifies a good plasma panel and also very likely to be an X-main issue.
                              • Jimmy Nolins
                                • Feb 2012
                                • 41
                                #35
                                Decided to scrap this one since its a EDTV
                                • cmj21973
                                  • 267
                                  Can you post a picture of the DP42545 remote?
                                  Depending where you're located, I might be interested in the set also.
                                  • Legend
                                    • Nov 2014
                                    If anyone on this forum has the stand (legs) for Sanyo DP42545 to spare please let me know.
                                    • manstoblame
                                      • Jan 2011
                                      • 85
                                      #38
                                      Outstanding, informative and very easy to understand!
                                      • ChaosLegionnaire
                                        by ChaosLegionnaire
                                        09-13-2022, 09:02 AM
                                      • hugocarmo
                                        Sanyo VHR-D4710G VCR no sound.
                                        by hugocarmo
                                        Hi again guys.
                                        Today I have a problem with this Sanyo VCR.
                                        I bought it online, It worked sometimes.
                                        I recap the Power supply and it started working fine.
                                        Image is perfect and all digital effects too.
                                        All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
                                        I have no sound on playback, on tuner, or aux in.
                                        On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
                                        On one of the sound processing...
                                        01-23-2024, 12:58 PM
                                      • LEECH666
                                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                        by LEECH666
                                        Good day ladies and gentleman!
                                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                        01-19-2024, 05:46 PM
                                        HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                        This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        09-12-2024, 02:30 PM
                                        HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
