Dell w2600
  • epicelite
    • Jul 2011
    • 58
    Dell w2600
    Why can I ever get one that's an easy fix?
    Anyway I hear this has a common problem with the BGA so I wanna try to reflow the board in my oven.
    I wouldn't even be posting but it has a lot of caps on it, do you think they would survive the heat in the oven for a short time?
    How do I even identify the BGA? I can't find a manual.
  • 999999999
    • Sep 2006
    • 774
    Re: Dell w2600
    BGA is just a type of chip, not which one it is specifically. Probably northbridge and/or GPU chip. Look up the cap datasheets, they should specify a temperature and # seconds. Don't exceed that. If any are electrolytic, no I don't think they will survive high enough/long enough temperature to reflow a BGA chip.
    What you really need is a hot air station not an oven to work on a populated mainboard... BUT, I have also heard of others reviving a board in the oven so good luck!
    • epicelite
      • Jul 2011
      • 58
      Re: Dell w2600
      Do you think an ol' cheap heatgun would work or do I really need a fancy hot air station?
        Re: Dell w2600
        This seems to be quite common with some users on this forum. The thing is, unlike the Xbox 360 and PS3, the main chips on these don't get that hot. They might have a small heatsink on them but that's all. And reflowing in the oven only fixes them maybe 40-50% of the time, but good luck.
        The caps will survive a high temperature temporarily, it will usually be specified in the datasheet (for wave soldering.)
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • bpjl
          SEF 551.10 - Error starting the reflow oven.
          by bpjl
          When starting the SEF 551.10 reflow oven, the following problem occurs:
          It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
          PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
          10-17-2024, 06:30 AM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
        • diamon
          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
          by diamon
          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
          Pictures of these boards:
          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
          Dell...
          02-28-2024, 12:51 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
