Dell w2600
  • epicelite
    • Jul 2011
    • 58
    Dell w2600
    Why can I ever get one that's an easy fix?
    Anyway I hear this has a common problem with the BGA so I wanna try to reflow the board in my oven.
    I wouldn't even be posting but it has a lot of caps on it, do you think they would survive the heat in the oven for a short time?
    How do I even identify the BGA? I can't find a manual.
  • 999999999
    • Sep 2006
    • 774
    Re: Dell w2600
    BGA is just a type of chip, not which one it is specifically. Probably northbridge and/or GPU chip. Look up the cap datasheets, they should specify a temperature and # seconds. Don't exceed that. If any are electrolytic, no I don't think they will survive high enough/long enough temperature to reflow a BGA chip.
    What you really need is a hot air station not an oven to work on a populated mainboard... BUT, I have also heard of others reviving a board in the oven so good luck!
    • epicelite
      • Jul 2011
      • 58
      Re: Dell w2600
      Do you think an ol' cheap heatgun would work or do I really need a fancy hot air station?
        Re: Dell w2600
        This seems to be quite common with some users on this forum. The thing is, unlike the Xbox 360 and PS3, the main chips on these don't get that hot. They might have a small heatsink on them but that's all. And reflowing in the oven only fixes them maybe 40-50% of the time, but good luck.
        The caps will survive a high temperature temporarily, it will usually be specified in the datasheet (for wave soldering.)
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • bpjl
          SEF 551.10 - Error starting the reflow oven.
          by bpjl
          When starting the SEF 551.10 reflow oven, the following problem occurs:
          It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
          PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
          10-17-2024, 06:30 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
          Dell Thunderbolt Firmware
          by SMDFlea
          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
          The SKU is in brackets (****)
          EDIT: NVM65...
          01-26-2025, 06:22 AM
