LG 50PG3000-ZA help needed please.
    Re: LG 50PG3000-ZA help needed please.
    Usually when one buffer is disconnected, the other loses some important control signals and goes a little crazy causing the repeated pattern.
    50" telly as a student... where will you put it... my dorm is really cramped!
    • nex91
      • Nov 2012
      • 37
      • Austria
      this tv is a gift from my brother,i wrote that... i dont have place too but i will find the way... if i repair it,sure.... thank you so much for help
        Yeah, I saw it was a gift. I was just making light of the fact that it's massive. Enjoy it when it's fixed. These newer LG plasma TVs seem to be pretty decent -- much better than the newer Samsung ones.
        • nex91
          • Nov 2012
          • 37
          • Austria
          THANKS,i have one more plasma tv, lg 42px3rva which is older one,that i have found here in this apartment in which i live now,but i wont turn on at all,dead... he have 2 bad capacitors in some board,i dont know which board is that,other seems fine at first look... what do you think, whats the problem with it? sorry for offtopic...
            Try replacing those first. If it still won't fire up, it's the Y-sustain or Z-sustain.
            • nex91
              • Nov 2012
              • 37
              • Austria
              #26
              can you tell me which are those 2 boards,from the main picture? i am new in those stuff...
                Left large board, Y-sus.
                Right large board, Z-sus.
                Looking from the back.
                I have had an LG with bad caps cause it to appear dead before, though it would show standby light after about 15 minutes of being plugged in. So I would say first, replace those caps.
                • nex91
                  • Nov 2012
                  • 37
                  • Austria
                  #28
                  i was not plugged it in for 15 mins,maybe 5... i will try... thanks a lot man,you rock
                    A hairdryer can get a TV to start up with bad caps. Just heat them up while the TV is plugged in.
                    Then you can confirm if it has other faults...
                    Here I demonstrate with a Samsung with crap bulging SAMWHA caps (I bet they are the same as on yours):
                    http://www.youtube.com/watch?v=Ggn_ggaPvc4&t=2m30s
                    • Olliez0r
                      • Nov 2012
                      • 6
                      Hi all, hope I'm not quite hijacking the thread, thought it was relevant enough to not have to start another...
                      Same TV (50PG3000)... can get sound but no picture at all..
                      tried disconnecting alternating buffer boards and I still get absolutely nothing.
                      People have mentioned an LED on a controller board as well as the power LED on the front... I don't see any lit LED on any of the boards inside the telly, can someone advise me as to where this LED should be and, if not lit, would it indicate that board specifically has failed?
                      Thanksssss
                        The LEDs are on this board -- top right:
                        https://www.badcaps.net/forum/attach...1&d=1353871947
                        • Olliez0r
                          • Nov 2012
                          • 6
                          Awesome thanks .. nothing lighting up on that board, does anyone have an idea/opinion on if... the lack of LEDs indicates this board is dead OR if it indicates a related board is dead?
                            I don't know -- but usually on an LG, those indicate temperature in binary. If they are not lit up, it may be normal if the set is still cold.
                            • Olliez0r
                              • Nov 2012
                              • 6
                              Hmmm! Well, I've checked the fuses with a multimeter and they're all fine, how's best to test the voltage on the other boards... I assume they should be getting power just like the AV board even if the controller board was dead.
                                There are a few regulators -- can you test those?
                                • Olliez0r
                                  • Nov 2012
                                  • 6
                                  Getting a reading off all three regs on the controller board - so it's getting power, think this is a sign that it is the controller that's borked as the LEDs aren't illuminating?
                                    It's possible. Those LEDs are controlled by the large "LG" processor in the middle of the board which also handles the plasma display functions... something wrong there would cause no LEDs to light up.
                                    • Olliez0r
                                      • Nov 2012
                                      • 6
                                      I reckon I'm satisfied enough to buy a new controller board - worst case scenario it's not what's broken and have to resell it Will post an update when it arrives.
                                      Thanks so much for the help
                                      • Olliez0r
                                        • Nov 2012
                                        • 6
                                        Controller arrived... works fine =D
                                        Thanks <3
                                          Thanks for posting the fix back. It will help others. Enjoy your fixed TV!
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                          • jshhh
                                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                            by jshhh
                                            Hi guys,
                                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                            Anybody know how to remove this type of fuse?
                                            (The fuse is toward the bottom of the image labeled F2)...
                                            06-17-2025, 01:35 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
