Hello All,
Long time lurker, first time poster.
Thanks for a great resource for people like me who don't think a marketplace built around "disposable" goods is such a good thing. Then again, I suspect most hoarders believe the same thing. Boy, don't let my wife know of my realization....
I've had this set back-benched for a while now, and I've made a promise to myself that I'd concentrate on getting it working (or proving that its beyond repair). I've followed a few of the posts on this forum and think I have narrowed it down to the Y-sus board. After reading through a few posts (on this and other forums) I found this post:
https://www.badcaps.net/forum/showth...ght=p42hdtv10a
I've worked my way through most of PlainBill's suggestions (except for the voltage adjustment on the Y-sus, because it won't stay up long enough)
I have the following to report-
1. When going for the voltages to the Y-sus, the sets protection kicks in before my meter can give me an accurate reading. Following PlainBill's advice, I unplugged the power leads to the Y-sus. Now the set does not go into shutdown, and I can get a reading coming off of the main power panel to the Y-sus panel. Voltages are in spec (Va=60v, Vs=186v). This leads me to believe that there is a short of some kind on the Y-sus. I don't see any signs of damage. None of the caps look to be bulged.
2. The set will go into standby (green LED turns orange) after about 30 seconds. I assume this is normal when there are no inputs detected. I can press the power button and the LED will turn green again. If I hold the power button down for a few seconds, the LED turns orange. This seems normal to me, but I have never seen this set in operation so I'm not 100% sure.
3. Lack of sound. I read that there's a fairly common problem where the Y-sus hybrid IC dies prematurely. This would be the no picture, has sound scenario. What would cause the sound to go bad as well? Hmmmm... second thinking this, maybe the set has just never stayed on long enough to produce sound before going into shutdown. I wonder if I can get sound when the Y-sus is out and the set stays on for a while. I'll get back to you on this.
I guess my main concern is verification of the Y-sus being the culprit. I'm currently critically underfunded, so I'm trying to avoid the "replace this and then try again" methodology. If I can be more than fairly certain what need to be replaced, I can probably justify the expense.
Thanks in advance for any help you can provide.
Xwell
Xwell
Great , Glad you tried to fix it yourself ... i opted not to fix the ipm on my set . Gonna send it out to get done . Next one i may try , i want to keep this plasma i picked up , got 2 more Plasma's coming ( smaller ones ) and 2 lcd's . On them i will give it a shot . Knwing you did it and got it buttoned up , gives me hope on my upcoming attempt.
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
