Re: Phillips 42PFL5432D/37 Chirping and No Picture
P6ke120a
Do you have a pn# of the two diodes you replaced?Leave a comment:
Thanks so much. I have a Philips 42pfl5432d/37b with the same problem, and after I changed the 4 caps and only one diode and the tv is back working like a charm!Leave a comment:
Wow, I am surprised this is working, you guys decided to replace ZENER diodes with regular diodes? They are marked ZD not D on the board, so must be zener diodes. Or am I missing something?
-BenLeave a comment:
My Philips did the same thing and thanks to y'all's help it is back up and running. I'm using the Radio Shack diodes; is there any long term risk if I keep those in?
http://www.radioshack.com/product/in...ductId=2062575Leave a comment:
My wifes friend was throwing this TV away did every thing you have suggested and it works wonderfull. New TV for $13.00 GOOD JOB.Leave a comment:
It works beautifully!Leave a comment:
This is what he got. Its not correct but truth be told he used the tv until the correct digikey ones were delivered.Leave a comment:
They have no FR or UF at radioshack, they don't even carry the 1N4007. Mainly 4005 and numbers a little lower.. If any of those would be safe i'd be willing to try. I'm looking forward to hooking it up!Leave a comment:
http://search.digikey.com/us/en/prod...ACT-ND/2770358 This is what we ordered.
I "think" tom was referring to if you do the radio shack diode to see if it works.Leave a comment:
Thanks for all your help.Leave a comment:
http://parts.digikey.com/1/parts/419...007-e3-54.html
UF4007 What he meant?
Edit: Also would the standard 1N4007 work for it? (JW)
http://parts.digikey.com/1/parts/719...-p6ke120a.html
This is currently in it.Last edited by tw1ztid; 01-23-2012, 06:39 PM.Leave a comment:
I'll start searching for FR4007 thanks!Leave a comment:
D912 is out of range, and .43
it's good.Leave a comment:
D925 is good. What about D912?
BTW, there is no such thing as "no reading". If it reads "1" on the left hand side, that means "out of range" or "infinity".
Remember a diode lets current one way and blocks the other way.
Hmm, we get this on a daily basis now. Time to write another guide. See
https://www.badcaps.net/forum/showpo...2&postcount=31
Edit: Checking D912Last edited by tw1ztid; 01-23-2012, 05:52 PM.Leave a comment:
https://www.badcaps.net/forum/showpo...2&postcount=31Leave a comment:
After removing it, D925 now gives me .463 and no reading the other way. So it looks good after allLeave a comment:
by BloopetaPhillips 58PUS7805/12, was told it had sound no picture, sometimes picture would come back then go again?
From what I have seen myself, its just blank illuminated screen. Tried unplugging each ribbon cable from Tcon in turn.
When one is unplugged, I get half sceen, clear picture.
With other unplugged, get half screen but with thin horizontal lines
Any ideas? Or is it likely a bad panel?... -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... - Loading...
