Phillips 42PFL5432D/37 Chirping and No Picture
  • tw1ztid
    replied
    Re: Phillips 42PFL5432D/37 Chirping and No Picture
    ZD904 .02 and .02
    ZD902 .05 and .05
    Havin a bitchin time trying to get these things out.
    Starting on removing the next two..
  • retiredcaps
    replied
    Originally posted by tw1ztid
    I'll start off by removing one leg of each diode and checking for false positives.
    Remove them and test them out of circuit. Report your multimeter results for each one.
  • tw1ztid
    replied
    Thanks, never seen a fuse other than the glass looking ones.
    All 4 read at .3, so they seem fine.
    So far we're down to either
    1) Diodes are bad and need replaced, casualties from when the Caps went bad?
    2) Another (larger?) part of the power board is causing a false positive.
    I'm leaning towards number one, like Mr. Bills situation, but I know to expect the unexpected.. I'll start off by removing one leg of each diode and checking for false positives. If they are, what do you recommend for being my first plan of action?
  • retiredcaps
    replied
    I'll remove them shortly then, I cannot find any other fuses on the inverter boards than the one on the power board..
    Fuses begin with the letter "F". For example, F100.
    Your 4 fuses circled in red.
  • tw1ztid
    replied
    Originally posted by retiredcaps
    If you switched the leads around, then yes all those readings suggest the diodes are all bad. You will have to desolder and retest out of circuit.
    It is possible that something else on the board is shorted and causing all these potentially false positives.
  • retiredcaps
    replied
    Ok, first results..
    ZD904 .02 and .02
    ZD902 .05 and .05
    D925 .07 and .07
    D912 .000 and .000
    I should desolder one side from each to retest now?
  • tw1ztid
    replied
    Ok, first results..
    ZD904 .02 and .02
    ZD902 .05 and .05
    D925 .07 and .07
    D912 .000 and .000
    I should desolder one side from each to retest now? I've repeatedly been getting the same results. There are other D and ZD diodes that the results came back fine.
    Edit: checking fuses right now, so far so good
  • retiredcaps
    replied
    Plug your red probe into the red circled spot. Black probe into COM. The black probe will always stay in COM.
    1) For the diode test, set the meter to the diode test function (blue).
    2) For the resistance test (fuse), set the meter to the 200 (two hundred) scale (yellow).
  • tw1ztid
    replied
    Got everything ready.
  • tw1ztid
    replied
    No worries. With power off and the TV unplugged, there is very little you can do to damage the TV, multimeter or yourself.
    Both the resistance and diode checks are done with the power off and TV unplugged.
    It is when the power is ON, that you have to be careful because one slip of the probe can cause a short.
    edit: See posts #19 and 20
    https://www.badcaps.net/forum/showthread.php?t=10419
    In the guide, I have sections on multimeter, fuses, and diodes.
    Thanks, that is 100x better than the video imo because it covers many different things. Was mainly worried that i wouldn't get the correct readings or short something. Be back later.
  • retiredcaps
    replied
    Sorry for that in advance.. lol.
  • tw1ztid
    replied
    Dont have it yet. Slow day at work and trying to be prepared. I know how much i question every little thing , and worry if i do it right I'm sure im overcomplicating it. Sorry for that in advance.. lol. Once i catch on to the basics it all gets very simple.
  • retiredcaps
    replied
    Continuity is fine to test the diodes though?
    1) Nope. Use the diode check function to check diodes.
    2) Post a picture of your multimeter.
  • tw1ztid
    replied
    I don't recommend checking fuses with the continuity feature. Multimeters vary with respect to what they consider "continuous". Some cheap multimeters beep "continuous" for any resistance measurement under 1800okohms. No fuse is good when the reading is that high.
    A good fuse should measure less than 1.0 ohms.
    Ok. Continuity is fine to test the diodes though? Be nice to not to have to remove diodes unless its the right ones if possible.
  • retiredcaps
    replied
    I don't recommend checking fuses with the continuity feature. Multimeters vary with respect to what they consider "continuous". Some cheap multimeters beep "continuous" for any resistance measurement under 1800 ohms. No fuse is good when the reading is that high.
  • tw1ztid
    replied
    If you mean multimeter, afrotechmods makes great videos.
    http://www.youtube.com/watch?v=bF3OyQ3HwfU
    That's perfect. Looks like i'll be checking continuity. Will be back to report in.
  • retiredcaps
    replied
    Any recommendations on a video teaching me how to use this thing correctly?
  • tw1ztid
    replied
    Originally posted by tom66
    FR4007 is 1kV not 600V, but any fast 1000V or 800V silicon diode should be fine. Don't get a standard 1N4007; it's nowhere near fast enough.
    Gotcha
    Or will this do, with same basic idea for fuses..
    http://m.youtube.com/#/watch?desktop...i_X7Ew3Y&gl=US
    replied
  • tw1ztid
    replied
    So i should have a multimeter in a few hours to check the fuses and diodes.
  • Bloopeta
    Phillips 58PUS7805/12 No Picture
    by Bloopeta
    Phillips 58PUS7805/12, was told it had sound no picture, sometimes picture would come back then go again?
    From what I have seen myself, its just blank illuminated screen. Tried unplugging each ribbon cable from Tcon in turn.
    When one is unplugged, I get half sceen, clear picture.
    With other unplugged, get half screen but with thin horizontal lines
    Any ideas? Or is it likely a bad panel?...
    03-10-2023, 02:08 PM
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
  • JJAAMM
    by JJAAMM
    Problem
    07-06-2023, 06:01 AM
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
