This is the same tv i got a month ago that had several bulged caps in the power supply. I recapped with panasonic FM caps. The tv worked fine until yesterday. I turned it on and the picture looked horrible. Almost like the brightness was turned all the way up. The tv ran for about 30 seconds before the power supply went into protection mode and shut down. The board on the power supply was flashing a code 1 which is VS. So i unplugged the tv for a minute before trying again. It turned back on. I quickly put my meter on the VS port on the power supply and the VS voltage was pretty erratic. It would fluctuate from 192v to 218v. Its supposed to be 207v. It almost seems that the voltage is fluctuating with the picture the screen is displaying.
So can the power supply be contributing to the horrible picture? I think if the voltage is too high or low the "sparkles" can appear, not sure about much else.
Or do you think the x-main or y-main has failed/failing causing the power supply to not give me a stable reading?
Is there anything i can do to somewhat rule out the power supply?
I can post a photo of the display if anyone would like to see.
