Panasonic LCD TX32LX500 can't power
  • spintop
    • Feb 2011
    • 132
    I have this Tv cannot power up and no LED lights at all. Check all components found no issue. But I found that the the switching transformer one primary side coils to be open.
    Is this open circuit due to the blown internal thermal fuse?
    I can't find any replacement transformer online, can the fuse be replaced and reuse the transformer? anyone tried this and is it safe ?
    thanks guys !
  • bbjunkie
    • Dec 2011
    • 301
    Re: Panasonic LCD TX32LX500 can't power
    See this post https://www.badcaps.net/forum/showpo...83&postcount=1
    Or entire thread here: https://www.badcaps.net/forum/showth...183#post204183
    It may be the same on your LCD.
    Good luck with the repair
    Jim
    • spintop
      • Feb 2011
      • 132
      thanks for the link.
      I have a question on the video. is the thermal fuse connected in parallel to the coils on the pins? he solders the new fuse to the pins of the transformer thus it's parallel.
      I would thought that the fuse is in series connection to the coils so that in the event the fuse blown the transformer will stop working
      • PlainBill
        • Feb 2009
        • 7034
        Think it through - there is a third alternative. In the above case the thermal fuse is the sensor for a protection circuit; it doesn't handle the load directly.
        If you are sure a primary winding is open it may be necessary to open up the transformer. It is very rare for windings themselves to go open. A thermal fuse or a bad solder joint are more likely, or the winding may have broken where it attaches to the pin.
        PlainBill
        • spintop
          • Feb 2011
          • 132
          thanks everyone.
          I will open up the transformer to look at it, inform you later.
          • spintop
            • Feb 2011
            • 132
            Hi guys
            I opened up the transformer, found the primary side coil with a broken wiring thus causing the open circuit. Found some corrosion on the thin wiring, its a 6 years old TV though. Found no thermal fuse.
            I reconnect the wiring and now the TV power up and seems fine.
            Thanks everyone.
            • PlainBill
              • Feb 2009
              • 7034
              Hi guys
              Thanks everyone.
              Good job!! A shop would have wanted $200 for the supply and $100 to install it. The supply would cost about $75 used. You invested some intelligence and a little labor and got it working for $.02 worth of solder.
              PlainBill
                Great fix! And thanks for posting the solution for others.
                Enjoy your TV.
                • bbjunkie
                  • Dec 2011
                  • 301
                  The cheapest repairs are always the most rewarding - especially when the cost of having a shop do it is so high.
                  Great work!
                  • spintop
                    • Feb 2011
                    • 132
                    The info and advice given here by all members are invaluable and very helpful in the process of fixing the tv. makes the job alot easier.
                    once again many thanks !!!
                    • corrize
                      A funny fuse story – Lumix LX100 II
                      by corrize
                      Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                      I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                      The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                      There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                      And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                      10-19-2023, 09:58 AM
                    • BigPete
                      Panasonic Heatpump Dryer Repair
                      by BigPete
                      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                      Unfortunately the whole machine has to come apart to fix it.
                      I have...
                      11-01-2025, 06:40 PM
                    • Andre Gilbert
                      by Andre Gilbert
                      11-20-2024, 08:52 PM
                    • ohren
                      Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                      by ohren
                      Hello!
                      I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                      Measured voltages with no load:
                      After rectifier diodes
                      12V: 6.17 V
                      5V: 5.67 V
                      Secondary transformer pins AC measurement (really don't know if this says anything)
                      12V: 2-2.5 V
                      5V: 1.04 V
                      I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                      03-18-2023, 10:33 AM
                    • jesterace
                      Samsung UE46ES8000 Blown fuse but no other signs of short
                      by jesterace
                      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                      09-11-2024, 03:14 PM
