Youtube-How to Repair a PANASONIC Plasma TV with Blinking LED TH-42PZ77U TH-42PZ700U
  • retiredcaps
    • Apr 2010
    • 9271
    Just saw this 15 minute video on gavincurtis's channel.
    http://www.youtube.com/watch?v=qQ_iL...1&feature=plcp
    Basically, for some Panasonic plasma TVs, there is a thermal fuse inside the secondary winding on one of the transformers. That fuse goes open and obviously the TV doesn't work. He shows this starting at the 5 minute mark.
    Now I have ZERO experience fixing plasmas and know only what I read here, but I haven't seen any case yet where there was a thermal fuse inside a transformer?? Or have I not been paying close attention?
    --- begin sig file ---
    --- end sig file ---
    Re: Youtube-How to Repair a PANASONIC Plasma TV with Blinking LED TH-42PZ77U TH-42PZ7
    Interesting. I've repaired a TH-42PZ80BA with a power board that looks the same to that, so I expect it would apply to that too.
    • mockingbird
      • Dec 2008
      • 5484
      I'm watching his CS80 videos. Fascinating. What an impressive synthesizer. Unfortunately, no one uses synthesizers well in music nowadays. Why does he always use GP capacitors (albeit Panasonic) though?
      • randtek
        • Oct 2011
        • 280
        • US
        In the last 20 years or so, I have occasionally found transformers that were internally fused. I learned about them years ago at a school on VCRs, I don't remember which manufcaturer. It seems like a generally bad idea to me though.
        • PlainBill
          • Feb 2009
          • 7034
          I have mixed feelings about this video. Obviously, identifying the nature of a failure is always a positive. It would be nice to know what the underlying cause was. Given that Gavin Curtis reported that essentially new power supplies (removed from TVs with screens damaged in shipping), it would appear the core of the transformer was inadequate. I was impressed with the detail he went into on the nature of the failure, and the parts requires for the repair. His use of an underrated thermal fuse would reduce the chance of overheating. The detailed instructions for disassembly were impressive.
          I was less than impressed with other parts. His explanation of the purpose of a PRC front end was laughable (or course, the purpose of the PFC front end is pretty laughable). The repair technique had a number of flaws. Needle nose pliers will make an adequate heat sink for soldering wires to the leads and assure better contact than crimp terminals. The wires themselves should have been anchored in place.
          PlainBill
          • Tuberon
            • Jan 2012
            Hi Tom 66 - I have a Panasonic TH-42PZ80BA bought in Dec 08 which has been absolutely fine for the past 3 years but has now developed the blinking problem and will not turn on. It blinks red twice then pauses and then repeats. It's been like this a few weeks making it difficult to turn on from fresh start but now it's not turning on altogether and been out of use for the past few days. When we try turn on we get click green flashing then click and off, back to double red flash, pause etc. As you've fixed one of these exact TV's can you (or anyone else maybe) please give me an idea where the problem might lie e.g. xsus board, buffer board...?
              Well, you'd be best creating a new thread - then start with posting pictures of the inside of your TV.
              Getting worse slowly sounds like bad capacitors but these Panasonics are very over-engineered, which is nice. They are usually full of high quality capacitors, Rubycon, Panasonic (who make their own capacitors), Nichicon and Chemicon. It could also be a bad solder joint.
              The service manual is here:
              2 blinks indicates "15V SOS" which means the problem is likely on the power board. If I recall correctly, the power (P) board generates a stable 15V, which is then stepped down to 3.3V & 5V by the PA(?) board, so the problem is most likely on the P board.
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
              • stecos
                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                by stecos
                Hi everyone!
                For my passion for technology I'm now collecting several...
                11-28-2022, 11:39 AM
              • cloo
                Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                by cloo
                I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                After doing a factory reset this problem was gone and the picture was back to...
                01-06-2025, 06:02 AM
              • Alicat
                Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                by Alicat
                Stopped by this site trying to fix my parents Panasonic Plasma TV.
                Model number is TH-50PZ85U
                Power comes on and the red power light stays on solid.
                Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                I also hear a few clicks.
                I also think my parents said there was a thunderstorm and the TV failed after that.
                Section 6 in the service manual talks about power and no screen,...
                10-30-2024, 10:09 AM
              • Lintesir
                Panasonic P42S30 Plasma - Pink sparkles
                by Lintesir
                My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                There is about a 5cm high region at the top without any sparkles,...
                07-26-2024, 03:16 AM
