Hello every one my name is shawn, this is my first thread/post. I am wandering if anyone knew where i could obtain a service manual for this Sanyo DP52848 lcd tv. The tv psu is receiving the turn on voltage from the pson but is not sending any voltage through the 12 and 24 volt outputs of the board.I have noticed a 10 volt signal and a .4volt signal on the secondary part of the board but have nothing on the primary side of the board.
Sanyo DP52848 Does not turn on
Tags: None
Re: Sanyo DP52848 Does not turn on
No luck of finding a service manual. Without one you have three options. There is a power supply available on eBay for $69, free shipping.
A second approach would be to do some basic troubleshooting. Very broadly, there are four possible causes for this problem.
1. The PSON signal is not getting to the PFC and main SMPS controllers and turning them on.
2. The main SMPS controller has failed.
3. There is an excessive load (probably from a shorted diode) on the secondary of the SMPS transformer, causing the current limiting of the controller to go into protect mode.
4. An external load is causing the SMPS to go into protection mode.
A quick and dirty test is to check the voltage across the main cap. If it reads about 375-400 volts when the TV is supposed to be on, the PFC is working, the PSON signal is getting through.
The second test is to disconnect all output cables from the supply and use a 3.3K resistor (2.2K - 4.7K should be good) between 5VSB and PSON to turn on the main supply. If it turns on, suspect a problem in one of the loads.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
Re: Sanyo PDP50XRDA no picture no sound
Hi
I am trying to help a friend whose Sanyo tv suddenly stopped displaying picture and sound. The tv does power up as the pilot lights turn red (Standby) to blue (on). I have successfully repaired a Philips plasma so when asked to assist I took on the challenge.
Initially, the tv would switch on from standby blue light would flash and then after a few seconds there would be a soft click and red light would come on again. Since replacing some caps in ps this return to stand appears to have been resolved. Still no picture and sound though.
The owner of the tv did mention there was a power outage in the suburb probably due to lightning strike - on closer inspection of the circuit boards - i noticed one of the chips on the main logic control board has what I can only describe as a 'surface irregularity' - something i have seen on a driver chip on a cd player after a capacitor popped.
Any advice, directions would be appreciated.
Thank you.Comment
by pajdekHello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
by RdeveLabsTo all the members here...
Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But... -
by robante15Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
If I remove the... -
by masoksianHi everyone,
I am dealing with the problem of turning on and off my Dell e7470 notebook.
The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
The system does not turn on, there is no post.
I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
The problem continues in the same way.
I tried to turn on the Fn key, nothing came to the screen.... -
by dqtechi got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
board number VIUX1 NM-A091 REV:1.0... - Loading...
