Dead screen, no pilot light
  • burntfingers
    • Jan 2011
    • 148
    Re: Dead screen, no pilot light
    Originally posted by selldoor
    Whilst it is probably the least of your problems you say "There is also 5 volts on the standby LED, but it does not turn on." could it be that the led is just burnt out?
    Can you try another led or try and light it with external power?
    ALSO
    Also you say"I have no means of getting any station or select AV." what do you mean? I can understand no stations but have you anything you can set up - a dvd player or vcr that you know is working and can attach by scart or composite cables then even without seeing the screen . Set it going then cycle through the function buttton or remote (if you have one) to see if you can hear the sound of the dvd or tape?
    Normally, I connect my colour bar generator with sound modulation to the RF aerial input or only video to RCA plug [yellow] and go from there. But I feel no heat in the sound amplifier and assume it is not processing anything.
    I can assume that there is sound, but that doesn't help resolve the main problem.
    • burntfingers
      • Jan 2011
      • 148
      Originally posted by tom66
      I didn't notice this board is using an add-on DC-DC converter. Check the output voltages on this converter, across the main caps. They should be 5V and 3.3V. Were these the voltages you were reporting when I asked you to check 5V and 3.3V?
      Those Lelon caps could be bad, too, but I think that would cause a low supply voltage, which would be obvious. Also, Lelon seem to think copying Panasonic's T-vent is fun, they can't seem to make up their mind about whether to use an X or a three-way star.
      I did check the two voltages on the caps and they read OK.
      But I was thinking: since the lamps voltage is correct and goes its normal way to their circuit, could it be something wrong there sending a feedback pulse to shut down the set?
      On a second thought I think not, because I have actually removed the plug that takes the 24 volts to the inverters and the result is still nothing.
        Do you have a 2.2k resistor?
        Try unplugging the inverter connector then pulling up pin #5 of PL602.
        • Rav_tangle
          MacBook Pro 2011 turns on with keyboard light , screen dead
          by Rav_tangle
          Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
          I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
          Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
          is this...
          05-31-2024, 04:09 PM
        • mecha1166
          QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
          by mecha1166
          I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
          03-28-2024, 08:31 AM
        • wushumike
          LG 65UB930T - Standby Light can trigger but TV dead
          by wushumike
          The problem: When remote controller is press, the TV seems to wake from standby light goes off; but there is no backlight, image and sound. The relay did click on.
          I have removed the power board to check. Using 2 x 10K resistor from 3.5V to PWR_ON AND DRV_ON, all the voltages is correct.
          The main board has a red LED and is lited, but the optic link does not light up.
          The Power board after sometime will start to blink x 5 interval.... I would assume this is to indicate DRV_On not working.
          Any expert here came across the same problem? I...
          03-27-2023, 09:46 AM
        • shagster
          TX-P50UT30B Dead - No Standby light.
          by shagster
          Hi, haven't been on the forum for a while. But I thought I'd ask here incase this has already been solved.
          Anyway, I have this Panasonic TX-P50UT30B. It's completely dead, no red standby light, nothing. I took off the back and had a look at the fuses. All of them are intact. No shorts when testing the mosfets of the Power supply either.
          And the capacitors look fine also.
          I'm guessing it's a main board issue. But I don't really know tbh. Maybe a corrupt firmware flash, dunno.
          02-27-2023, 10:07 AM
        • NeilMcG
          Hp Elitebook - Dead Screen
          by NeilMcG
          Hello all,
          First time posting, so please be gentle 😂
          HP Elitebook 850 G2 Win 10 with Intel HD Graphics 5500.
          Screen dead, but booting.
          I connected it to an external monitor via both VGA & Display Port outputs and external monitor works fine, nothing with F4 or detecting another screen in settings.
          Got a replacement panel, still dead & still displayed to external screen as before.
          Removed CMOS & left it. CMOS reconnected, all as before, no panel, external monitor works.
          Got replacement cable...
          12-06-2024, 03:23 AM
