Vertical line
  • burntfingers
    • Jan 2011
    • 148
    Vertical line
    This is another Chinese LCD set, apparently assembled in Portugal with various different panels.
    Brand name is a private one - DigitalArt.
    Not listed anywhere!
    Customer sent two for repairs, the other one is dead, but the power seems to be going [I already sent email to LiShin Enterprise for diagram of PS - not sure if I'm lucky - PS model n. 0420D02216].
    Is this a screen problem or plugs?
    I have not yet stripped it to check because I'm not sure if customer wants to replace screen [if it is the screen].
    Apparently, he can get a new screen from where I don't know!
    Re: Vertical line
    Looks like panel, sadly - unlikely to be T-con.
    • burntfingers
      • Jan 2011
      • 148
      Re: Vertical line
      Thanks.
      Is it worth checking any anomaly in the plugs to the screen panel, do you think?
        Re: Vertical line
        Originally posted by burntfingers
        Thanks.
        You could try pressing on them, if you are lucky it will just be that and may be fixable.
        • rmoody
          Learning Member
          • Jul 2011
          • 262
          Re: Vertical line
          I once had a vizio with similar vertical lines like the first picture and it ended up being the tcon
          • almarhum
            To fix laptop screen vertical line by working on its EDP cable
            by almarhum
            Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
            As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
            05-07-2024, 02:12 PM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • ahoonid
            MacBook A1990 vertical stripes on external screen
            by ahoonid
            Hey everyone,
            I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
            The board is neat. Not opened before for sure. Just a little dust, nothing more.
            Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
            06-20-2025, 08:54 AM
          • Firentiosi
            1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
            by Firentiosi
            Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
            The issues are as follows: the...
            11-27-2024, 12:33 AM
