Samsung LN40B650T1F won't power on
  • MEB
    • Sep 2013
    • 371
    Re: Samsung LN40B650T1F won't power on
    bump
      Does the problem occur on all inputs? Does it affect the menus?
      • MEB
        • Sep 2013
        • 371
        OK, before I could get back into trying to answer Tom's questions about the inputs, my friend informed me that the TV died while his wife was watching it. I have been reading posts and wanted to try to find out some information before posting back. Here is what I tried.
        I have attached again power board photos, schematic from Tom, and datasheets for easy viewing.
        TV is still at my friend's house. After replacing the bad CCFL, the TV worked fine, except for the aforementioned line. Then while viewing a program, the TV quit with no further signs of life. When plugged in there is nothing. Remote will not even light the power LED.
        Had my buddy remove the back and told him to check fuses FS801S and FM802S on the power board. FS801S was good, FM802S was open. It is a 3.15A 250V ceramic fuse. I remembered reading a post by budm, and although I didn't really understand the theory, I made a 75W “test lamp” by soldering a bulb to a spent fuse and had my friend plug it in the fuse holder. I told him to watch the light. The light lit up very brightly as soon as the unit was plugged in to AC. See attachment if you wish. I told him if the lamp lit, to power off and then pull the connector to the ribbon cable from the power board at CNM802 and try again. Right or wrong, my thought was that would tell me if the problem was on the power board or farther down the line. The lamp lit up again. So upon getting that report, I figured the power board itself to be bad and told him to remove it and bring it to me. Budm would be proud as this time he left the sockets in the TV! (some earlier humor)
        Armed with a meter, the schematic and not much knowledge except countless hours of reading Badcaps, this is what I found up to this point.
        Q1821 reads shorted from G-S-D on ohms or diode mode.
        Q1820 reads shorted from S-D, G-S and G-D read 120 or 138 depending on lead orientation.
        QP801S and QP802S I would say are OK.
        UM801S is nearby but didn't know what to do with him.
        I would guess from previous reading to remove Q1820 and Q1821 from board and retest, but I would feel better with some advice before I get into trouble. Should I try to check anything else? Thanks in advance for any help.
        • MEB
          • Sep 2013
          • 371
          bump
          • MEB
            • Sep 2013
            • 371
            fishing
            • MEB
              • Sep 2013
              • 371
              I did remove QI801 from the board and it reads shorted everywhere. Guess I will try to find one. There was some sort of reinforcement in the through hole for that device. Is that typical?
                It is normal.
                If this is like the other Samsung boards I remember this is a common fault.
                You only need to replace the FETs - you can leave the other components alone because it is driven by transformer, so damage to the control ICs is rare.
                • MEB
                  • Sep 2013
                  • 371
                  Thanks Tom. I just checked Digikey and Mouser and it seems this device is obsolete. I will see if there is an equivalent in these posts. Thanks again.
                  I think I recall July to be your start work month?
                    I start on the 7th, so my availability for help over the next year will decrease significantly.
                    You only need to match a new FET to the following parameters: Qg same or less, Rds(ON) same or less, Vds same or higher, Id same or higher.
                    • MEB
                      • Sep 2013
                      • 371
                      Thanks very much for the device info. I don't mind helping myself and with that information I think I can find a suitable replacement. Thanks again.
                      Good luck with your new job. I have no doubt they will never want to let you go. I (and everyone) will be hoping you have time to still hang out with us.
                      • MEB
                        • Sep 2013
                        • 371
                        Per Tom's post above I chose a Fairchild FDPF8N50NZU Mosfet as the replacement and replaced both QI820 and QI821. Sent the board back with my friend. He installed it last night and reported that the TV is working wonderfully. Thanks again to Tom and others who helped me learn so much during this adventure.
                        • triplefour
                          • May 2014
                          • 1747
                          i just came into one of these tv's and it also has the 3.15A fuse blown... thank you for taking the time to fix this tv and giving me a place to start
                          Don't fear the repair...
                          • C152Heavy
                            by C152Heavy
                            Summary for TL-DR readers:
                            • VCC pin (18) of PFC...
                            01-11-2023, 02:53 PM
                          • Destroyer-Br
                            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                            by Destroyer-Br
                            I'm working on an Acer Nitro 5 unit with the following specs:
                            • Motherboard: LA-J871P Rev: 1B
                            • Model: Acer AN515-55-59MT
                            • S/N: NHQ7JAL00403906A973400
                            • SNID: 03902728734
                            Initial Issue
                            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                            04-17-2025, 08:18 PM
                          • Dani_2024
                            by Dani_2024
                            10-28-2024, 05:06 PM
                          • repair-it
                            Need advice testing a samsung power supply board with scope
                            by repair-it
                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                            07-12-2025, 11:00 AM
