LCD Samsung LA32B350F1 - sound, no picture
  • burntfingers
    • Jan 2011
    • 148
    Do I need to suspect one of the inverters?
    Sound is there OK, but a perfect picture only appears for a second or less any time it is powered, on the standby touch button.
    Sadly, the Manual does not have the diagram.
    Manual suggests replacing the entire PS board [which, I guess, would not be cheap - customer wouldn't accept]**.
    http://elektrotanya.com/?q=showresul...at2=schematics
    ** Are these LCD sets getting more into the disposable "dispensation" with such faults?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: LCD Samsung LA32B350F1 - sound, no picture
    That would be a good guess at 2 seconds to black. See
    http://lcdparts.net/TransformerDetai...ProductID=3944
    for the secondary pins.
    Measure both transformers and see if all 4 readings are within 3% of each other. Post your measurements.
    $20 on ebay + free shipping if that is the problem.
    --- begin sig file ---
    --- end sig file ---
    • burntfingers
      • Jan 2011
      • 148
      Secondary readings are similar - on one, there is a slight difference [1003 Ohms instead of 1030].
      Would the set run on half of the lamps if I removed the suspected inverter?
      • randtek
        • Oct 2011
        • 280
        • US
        That minor diffrerence is probably insignificant. I would supply a single color test pattern and look carefully at the screen before it goes out. Do you see any areas that look slightly darker? It could be a bad CCFL (cold-cathode flourescent lamp)
        • burntfingers
          • Jan 2011
          • 148
          Thanks for the tip - I will try it next.
          The normal TV picture looks OK, but I will feed a red signal and watch.
          • burntfingers
            • Jan 2011
            • 148
            Yes, there is a band of about 15 centimeters on top of the screen, with gradually less light.
            The very top edge is with the least light.
            The rest has perfect red.
            • randtek
              • Oct 2011
              • 280
              • US
              The very top lamp is out. If you are brave, you can try dsisassembling the panel and replacing the bulb. They are available from sources on the net. You could also look for a used panel.
                It's not always the lamp. Sometimes the blue capacitors can fail open circuit. Try swapping the lamp connectors around: for example plug the topmost lamp into the socket below and vice versa - then see if the band is fixed (lamp failed) or if it moves (cap or transformer).
                • burntfingers
                  • Jan 2011
                  • 148
                  Oh, that would be an easy one, I guess!
                  But I will check them tomorrow - I already checked them for shorts in-circuit and nothing strange to mention.
                  As for stripping the enclosure with the lamps, not the easiest jobs.
                  I know another friend who also has exactly this same model, and I guess this would be some sort of a stock fault that I will have to repair sometime again.
                  It would very nice to fix this one first.
                  • burntfingers
                    • Jan 2011
                    • 148
                    Checked blue caps - 3pf 5kv - OK.
                    Swopped lamps, same result: top one not on.
                    Swopped inverters, top lamp now OK, third not on.
                    [Still on only for a second]
                    Conclusion: faulty inverter.
                    Must I replace both?
                      Are you sure about 3pF? That's very low. Typically it's 20-50pF.
                      • burntfingers
                        • Jan 2011
                        • 148
                        Actually 3pf, 6kvolts.
                        Check proof.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          No. the transformers, part number QGAH02107, are available for $20 on eBay. I suspect you did not measure the windings correctly. There are two secondaries on each transformer, it is almost certain one of them is open.
                          PlainBill
                            Interesting CCFLs. Never seen curved ones like that.
                            Anyhow, note how the faulty inverter output is very dim but it is lighting up slightly; this generally rules out a driver problem. Double check the secondaries as PlainBill suggests but also check the wiring and the orientation of the connector (it sometimes matters which is white and which is pink/blue/other.)
                            • burntfingers
                              • Jan 2011
                              • 148
                              Thanks, guys.
                              Went back to measure transformer pins [in circuit], and they show:
                              Ti 801
                              1-2 = 1021 ohms
                              2-3 = 1023
                              Ti 802
                              1-2 = 993
                              2-3 = 1031
                              [Remember I swopped the transformers - originally the reading 993 was for the faulty lamp on top of screen; now lamp number 3 is the one not lighting]
                                993 is on the low side, and outside 3% tolerance compared to the average of 1025.3, so consider replacing it, but before you do that - check the primaries; should appear as a near dead short; check the FETs (should be open); check the fuses (if any.)
                                • burntfingers
                                  • Jan 2011
                                  • 148
                                  I will do that, thank you.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Ti 801
                                    1-2 = 1021 ohms
                                    2-3 = 1023
                                    Ti 802
                                    1-2 = 993
                                    2-3 = 1031
                                    In post #2, I included a link identifying the secondaries.
                                    I don't know your numbering scheme above with 1-2 and 2-3, but if you use the link what are the resistance measurements for S1-S2 and S3-S4?
                                    • burntfingers
                                      • Jan 2011
                                      • 148
                                      Final report:
                                      Customer agreed with quotation and the power panel was replaced, fixing the problem.
                                      Could not get one inverter from agent: had to get the whole board.
                                      • aswan@vodamail.co.za
                                        • Apr 2015
                                        • South Africa
                                        Just for interest. I had the same experience with the same model. What I found to be the problem was one of the inverter transformers.
                                        I did the flaslight test first and saw display and sound without backlight.
                                        How I got to that was by swoping the 2 inverter transformers. The dark line moved from second top lamp to bottom lamp. Trying that is alot easier than changing lamps. My supplier did not have stock of the inverter transformer so I had to replace the complete board. As soon as they get stock I can replace the faulty inverter and have a working board on hand.
                                        I must also mention that this seems to be a common fault on various screens and tvs. On for a second and then off. I want to thank the person that came up with the flashlight test.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
