LG 42LC46 problem
    replied
    Re: LG 42LC46 problem
    I see at least one regulator on the board.
    Get out your multimeter. Set it to 20VDC. Place the black probe on the metal chassis; for example, a part of the metal frame like a spare screw hole. Then, turn the TV on (and make sure the picture is good.) Measure the voltage on each pin (using the red probe) - for the middle pin, measure the tab as they are connected to each other and it's easier to measure, and report the readings. Then, wait for the picture to go bad, and measure again.
    Use a loupe to read the part number and report that back.
  • sienoki
    replied
    Originally posted by sienoki
    this is best pic at mo
    heres another
    replied
    See my edit...
  • sienoki
    replied
    I will have to borrow a decent camera as mine is crap
    replied
    Even a crap picture might be enough to identify regulators on the T-con...
    Here are what regulators look like. The three leg + large tab black devices are LDOs. In this set they are adjustable regulators, all of which are set to 2.5V.
    The bottom one on this T-con failed, causing various colour lines on the screen + no visible image.
  • sienoki
    replied
    Originally posted by tom66
    Post a close up picture of the T-con... you may need to remove the shield.
    I have a Samsung that has a strange picture occasionally, caused by a dodgy LDO (voltage regulator.)
    replied
    Can any1 help me test further plz..i have 90quid in this set and would be a shame to get rid..thx
  • sienoki
    replied
    this is the picture after 20mins
  • sienoki
    replied
    The replacement t-con arrived today..installed it but still no joy
    I wont pretend i know what im doing cos i dont..i feel im learning quite abit from other threads and definateley apreciate your help so far.
    Now its time to start with my multimeter..on my psu there are 3 pin outs together..2 with the block wires going to the main board and 1 not in use..is that the test pin out..if it is i took readings when the unit is powered on(scary)as i dont to blow myself up..anyways readings are as followed
    3.4v=3.47
    GND=0.00
    6.5=6.33
    GND=0.00
    12v=12.25
    GND=0.00
  • sienoki
    replied
    3.4v=3.47
    GND=0.00
    6.5=6.33
    GND=0.00
    12v=12.25
    GND=0.00
    should i now take readings from the other 2 pin outs..if so do i need to take the block wires out and take readings with the set switched on..thx
  • sienoki
    replied
    I will have to start my test another time as i use my bed to put tv on and now r lass is asleep in it..thx 4 ur help
    3.4v=3.47
    GND=0.00
    6.5=6.33
    GND=0.00
    12v=12.25
    GND=0.00
  • sienoki
    replied
    Okay, those caps are fine.
    Set the multimeter to the 20V range and measure all the outputs on the power supply.
    replied
  • sienoki
    replied
    ZL series of rubycon-ultra low impedance 5x10v-2200uf
    the others are rubycon aswell apart from 2 panasonics 10v-470uf and 25v-47uf
    I met a bloke at farnells today in Leeds..he said he was a mod on here but didnt get his name as our lass was left outside for 30mins
  • sienoki
    replied
    replied
    What capacitors did you use to replace the originals?
    It could be a T-con fault. I've got a Samsung on my hands at the moment that has lines on the screen with no image visible, but sometimes after it warms up the picture comes back. I suspect the T-con is bad. It's possible, although unlikely, that bad caps could damage the T-con.
    Can you list the ranges/settings your meter has - does it have a 20V or 40V range?
  • sienoki
    replied
    I checked the solder joints and they are all good..i tried the hairdryer on t-con and main board with no results..ive changed 9 caps on psu from 35v downwards..would you also reccomend replacing the smaller caps on psu that are above 35v they also them crap named 1s..can t-con boards work for 10mins and just fail..thx
    I bought a cap..diode tester from farnells on clearance shelf but dosent even work..i have a standard multimeter..thx
    Hi..i have since replaced all caps on my psu..after 10mins still same so i then left it on for 30mins and picture is like photo..if i buy this t-con card and still same probs could some kind and patient soul walk me through how to use my multimeter and where to start as i am totally new to all this..thx
    sos for crappy pics..
  • sienoki
    replied
    replied
    How would i use the hairdryer to localise the fault..thx
    Get out the hairdryer, heat up individual areas around the capacitors, T-con and main board, if the fault shows then turn it off and test again, if it shows again then you have found the suspect area. Good for finding cold joints and bad capacitors (which don't always bulge.)
  • sienoki
    replied
    Hi tom thx for answering back..am fairly sure solder joints are good i will check them again..yes i get a good picture for 10mins at a time..the LVDS is seated firmly in..Im totally new to electronics but have repaired 3 lcds been lucky they where only bad caps..think im gonna order a t-con board..theres only 1 on ebay thats from a smashed screen and he dosnt state thats it been tested so might take a chance on it..How would i use the hairdryer to localise the fault..thx
  • THXFX
    samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
    by THXFX
    Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
    I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
    When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
    What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
    I check capacitors and diodes and didn't find any short IN MAINBOARD.
    Measured all power supply...
    03-20-2024, 03:21 AM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • advant
    by advant
    02-03-2020, 12:25 AM
  • Zeonalbasta
    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
    by Zeonalbasta
    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
    09-13-2024, 01:17 PM
