Samsung 50inch Plasma - colored sparkles (videos in thread)
  • tjahyadi
    • Nov 2013
    • 4
    • Indonesia
    #81
    Re: Samsung 50inch Plasma - colored sparkles (videos in thread)
    Originally posted by tjahyadi
    Hi, Problem solved !!!.......I'm very happy now..... After I replace Y Sustain Board (Y main board) with new ones, the picture not dark anymore, and colour is absolutely normal also more bright then before. In addition I added some heat sink to prevent overheating in its original usage especially for long term use.....in fact until now still be a question mark for me about which item has been damaged in the old board when all voltages have been measured in accordance with note that it is recommended as Va, Vsc, Ve, and Vs, there may be some Buffer IC damaged and could not be measured.......!
    • keithf2
      • Aug 2010
      • 131
      #82
      Can some one tell my how to start a new thread
      • chris333j
        • Jun 2019
        • 8
        • France
        #83
        Hi, I have a similar plama samsung (ps50c96hd) and the picture is very bad.
        I'm new in this forum so i edit this post, sorry for that...
        The picture :
        With no signal there are grey point :
        I have control all the voltage (Vs, Vsc, Va, Ve...) all is good.
        On the Z card (on right) i just replace a capacitor (25v 680mf) but no effect.
        I have change the t-con module but no effect...
        If you can help me plz
        • chris333j
          • Jun 2019
          • 8
          • France
          #84
          I have change the t-con (control) and the power-card but no effect.
          The problem :
          https://youtu.be/GxG9rA_kXFw
          Thanks a lot for any idea...
          • chris333j
            • Jun 2019
            • 8
            • France
            #85
            Good evening, I reconnected the television without the x-main control card and ... the image remains exactly the same, there is only the sound that has disappeared. It's strange, is not it? Thank you
            • Lintesir
              Panasonic P42S30 Plasma - Pink sparkles
              by Lintesir
              My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
              There is about a 5cm high region at the top without any sparkles,...
              07-26-2024, 03:16 AM
            • PNI E.
              Tv grundig 50vlx21ldl horizontal colored limes
              by PNI E.
              Good morning guys, I have this tv that have horizontal colored lines ( green, blue, black). I tried to disconnect the two ribbon cable on the t con, first the left side and then the right side. But the lines still are there…so I tried the tape method but didn’t work. Can someone help me to try to fix this tv. I give you the photo of the panel, and the panel with the left ribbon unplugged and then the right. Thanks for your help...
              06-11-2025, 09:45 AM
            • alro7779
              Samsung UN55MU6103F video problem; has colored stripes on the display
              by alro7779
              Hello, everyone!
              A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
              09-27-2025, 11:29 PM
            • rapid911
              Vizio M58Q7 colored horizontal lines
              by rapid911
              Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
              05-28-2023, 04:17 PM
            • Maverick1234
              Colored Vertical lines on Samsung UN55C6400RF TV
              by Maverick1234
              I have a Samsung 55inch TV (UN55C6400RF). It has started showing colored vertical lines. I have opened the TV and the power board had one pin (out1-) which is discolored (Model # bn44-00358b). Can this be bad or is it the T-Con board (Model # D03464E0J09B6012066). Any recommendations on diagnosing the issue?
              Thanks,
              Sanjay
              09-13-2021, 02:43 PM
