Samsung 50inch Plasma - colored sparkles (videos in thread)
  • dustinarden
    • Dec 2011
    • 44
    #41
    Re: Samsung 50inch Plasma - colored sparkles (videos in thread)
    thats what i did originally.
    i was able to eliminate most of the sparkle. Going too far left or right on the dial causes WAY more sparkles to show up. figured i would give the yfr a shot too, but i've got them both dialed to the point to where sparkles are minimized i believe.
    • dustinarden
      • Dec 2011
      • 44
      #42
      ok i redid it.
      i adjusted out the blue bar with the YFR then used the YRR to dial back the sparkles again most of the way out ...
      they are still there, but better than before i started this whole thing.
      so blue bar gone .. most of the sparkles are gone, but not all of them.
      should i shoot another video showing?
      also which Cap are you guys referring to?
        Okay. From what I remember, LG had this problem with a lot of their plasmas. The solution was to replace the logic board, however, I wouldn't recommend that. What most people discovered was setting Vs a bit low would improve this. Try tweaking it to around 195V.
        Right now I'm out of water, I haven't touched a plasma in a while and haven't got one to play with now to test some of these theories. I'm going on what little I learnt when I repaired the Samsung 42".
        • dustinarden
          • Dec 2011
          • 44
          #44
          are you guys referring to the big brown cap on the power board?
          it slightly looks like its bowing out a hair, but it could just be me ... if it is bulging is HARD to tell for sure ...
            ok i redid it.
            The big brown one. Next to Vs.
            I just realised we have forgotten to test Ve. I'm wondering if that little add-on daughterboard you mentioned has something to do with it. Can you get a picture of it, from the component side? (the side with the parts on it)
            • dustinarden
              • Dec 2011
              • 44
              #46
              i lowered the Vs and watched the picture as i did it and it got way worse ...
              are you saying i should lower the Vs to that range and then readjust the YFR?
              • dustinarden
                • Dec 2011
                • 44
                #47
                the YFR is on the daughter board, not the Ve ... i cant find the Ve anywhere ...
                • dustinarden
                  • Dec 2011
                  • 44
                  #48
                  wait .. i found the Ve adjust, but i cant find the test location .. one sec ..
                  • dustinarden
                    • Dec 2011
                    • 44
                    #49
                    haha .. ok i found the Ve ... its dead on at 115 which is where the sticker says it should be.
                      Okay. I would raise the Vs back to 203V and leave the timings as is. The Ve might be causing this, but the 42" I worked on had a Ve of 0V. Not sure what its purpose is... does anyone else know??
                      • dustinarden
                        • Dec 2011
                        • 44
                        #51
                        i moved the Ve all the way to 65 and hardly anything changed ... moved it back to 115 though, lol
                        i guess i can live with this, but was hoping to be able to find out which board was causing it so i can replace it.
                          Last ditch attempt... I read up on it a bit... try lowering the Vscan voltage by about 5 or 10 volts.
                          This can be caused by panel aging, i.e. as the screen gets older it wears out, so it might not be a simple board swap...
                          • dustinarden
                            • Dec 2011
                            • 44
                            #53
                            Well poop
                            On the bright side it does look better ... thanks for the help guys!
                              Well poop
                              Did you try adjusting Vscan a little?
                              • dustinarden
                                • Dec 2011
                                • 44
                                #55
                                went back to the vscan ... adjusted it a bit and then touched it again ..
                                sparks flew
                                now i have this crazy flashing pattern on my TV.
                                guess i'll be replacing a board afterall.
                                http://youtu.be/iTLzfLtsCns
                                please tell me i can test a few voltages somewhere and determine exactly what i need to replace?!
                                superbowl is only a few weeks away and i'm hosting a party
                                  sparks flew
                                  I'm guessing something touched something it shouldn't, or the voltage went too high. The good news is the picture is still there, so it's probably a voltage that's gone out of tolerance - check them all. (It's possible the spark made you jump and you turned the Vscan pot too far... I've done the same with an old RPTV but damn, you never get used to a shock from 200V.)
                                  • dustinarden
                                    • Dec 2011
                                    • 44
                                    #57
                                    i've turned the vscan all the way up and down .. the voltage doesnt really change the pattern, but it does jump between 200 and 230 with a few points in between that match up to the flashing on the screen. does that mean this board is shot, since the voltage isnt stable anymore?
                                      That might be the problem, unfortunately. Can you hear a buzzing in time with the flashing? Try to locate what went bang - the good news is it should be obvious (burnt/melted component, charred marks on the board) and it will be easy to fix (just need a soldering iron.)
                                      Double check Yfr/Yrr, as I've seen this pulsing occur on a plasma when they are near the end of the range.
                                      • dustinarden
                                        • Dec 2011
                                        • 44
                                        #59
                                        i dont really hear a buzzing, but the spark shot directly out of the vscan adjustment pot ..
                                        i'm searching for burnt/charred marks and i'm not seeing anything.
                                        since the spark shot straight out of the vscan test pot i'd say its a safe bet that board is shot?
                                        the other voltages appear to be stable .. its just the vscan one
                                        • dustinarden
                                          • Dec 2011
                                          • 44
                                          #60
                                          i take that back .. the va and vs are fluctuating too .. just nowhere near as much as the vscan
                                          • Lintesir
                                            Panasonic P42S30 Plasma - Pink sparkles
                                            by Lintesir
                                            My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                            There is about a 5cm high region at the top without any sparkles,...
                                            07-26-2024, 03:16 AM
                                          • PNI E.
                                            Tv grundig 50vlx21ldl horizontal colored limes
                                            by PNI E.
                                            Good morning guys, I have this tv that have horizontal colored lines ( green, blue, black). I tried to disconnect the two ribbon cable on the t con, first the left side and then the right side. But the lines still are there…so I tried the tape method but didn’t work. Can someone help me to try to fix this tv. I give you the photo of the panel, and the panel with the left ribbon unplugged and then the right. Thanks for your help...
                                            06-11-2025, 09:45 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                          • rapid911
                                            Vizio M58Q7 colored horizontal lines
                                            by rapid911
                                            Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
                                            05-28-2023, 04:17 PM
                                          • Maverick1234
                                            Colored Vertical lines on Samsung UN55C6400RF TV
                                            by Maverick1234
                                            I have a Samsung 55inch TV (UN55C6400RF). It has started showing colored vertical lines. I have opened the TV and the power board had one pin (out1-) which is discolored (Model # bn44-00358b). Can this be bad or is it the T-Con board (Model # D03464E0J09B6012066). Any recommendations on diagnosing the issue?
                                            Thanks,
                                            Sanjay
                                            09-13-2021, 02:43 PM
