Technika LCD19DVDID dead
+ More Options
Posts
  • bbjunkie
    • Dec 2011
    • 301
    Some may recall a recent thread where I mentioned I had got this set given to me not working, I fitted two new caps in the primary side of the psu and the TV part was running again.
    Today I decided to attempt repairing the DVD player in it, plugged it in, I nearly jumped off the seat when I pushed the plug into the wall there was a loud splat and I thought oh no...
    Sure enough the PSU is totally dead on the output. Got 320VDC across the smoothing cap on the input. I haven't traced it any further yet, could do with a schematic.
    Anyone got a service manual or even just a schematic for the APC007-G power supply unit that these use?
    I've searched Google, Elektrotanya, eServiceinfo - the lot.
    Haven't posted any photos as my camera isn't focusing properly, have borrowed another and have it on charge so pics will follow.
    Jim
    Re: Technika LCD19DVDID dead
    Well, splat is good - quite likely, some power component has gone bang, but that should be all. Bad diode?
    • bbjunkie
      • Dec 2011
      • 301
      I spent last night reading a few SMPS documents, including the one at the repairfaq site. An extract from it says:
      Substitutions of low ESR caps into circuits which had lousy caps is not always the good idea that it appears to be.... Caution is advised, as low ESR caps will not limit surge currents.
      The circuits' series impedance drops (compare substituted capacitors ESR when new with the original capacitor's ESR was when it was a new capacitor), which, in turn, lets the surge magnitude rise, the higher currents destroy can semiconductors and other components.
      Could this be my problem? the lower ESR allowing a larger inrush causing a failure once connection was made to the wall socket?
      Going out to the workshop in a bit to investigate further (have checked the switching MOSFET before tom66's post came in and it seems fine, am planning to check diodes as suggested next)
        I don't think so, as these power supplies are current limited. On power supplies with coils, it might matter more.
        • bbjunkie
          • Dec 2011
          • 301
          Ok.. That had me thinking I may need some other caps, thanks for putting my mind at rest!
          Checked the 3 pin diode and Zener in the secondary side and the diode in the primary near the switching transistor, All seemed ok (out of circuit). I have however discovered an unstable 5.0 - 9.5VAC on two of the three output pins on the transformer between the primary and secondary.
          The pics im taking are still not great, but hopefully these two are suitable.
          Jim
          • bbjunkie
            • Dec 2011
            • 301
            Only two other pieces of silicon on the board, so may as well pull those and test I thought...
            Removed the optoisolator OT1 and checked it on the multimeter. With the diode function I am seeing a voltage drop of 0.9 volts between 1 and 2 (in one direction) however when I measure resistance between 1 and 2 I am seeing an open circuit in both directions.
            I am also seeing an open circuit in both directions on pins 3 and 4
            The markings on the optoisolator are:
            L0701
            817C
            Have I discovered my issue?
              That seems okay.
              Do you get any output voltage, at all?
              Faint ticking/whining?
              How's the output diode, is it shorted?
              • bbjunkie
                • Dec 2011
                • 301
                I'm back indoors now, from memory there was nothing, perhaps 0.01v or so on the output.
                No noises at all.
                I assume the output diode is the 3 pin device screwed to the heatsink by the output (the marking on the PCB confirms it is a diode device)
                  Yes, that's most likely the diode. Does the PSU have only one rail? Most usually have auxillary rails (5V usually, sometimes 3.3V, maybe another rail ~15V-24V for audio depending on output power) because it's more expensive to add step-down converters on the main board. There might be SMD diodes on the bottom of the board.
                  Test all three combinations 1-2, 2-3, 1-3, 2-1, 3-2, 3-1 for shorts.
                    master hoarder
                    • May 2008
                    • 12170
                    While this may not be what caused your problem, you have some of that brown/tan glue on the primary side near D8. The brown/tan glue turns conductive with heat and age and also corrodes metal contacts. Remove as much of it as you can.
                    Post a picture of the underside of the PSU as well. The PWM controller is likely to be found there.
                    • bbjunkie
                      • Dec 2011
                      • 301
                      Going by the markings at the power connector, there is a 5.3v and 12v rail.
                      Diode checks showed:
                      1-2 o/c
                      1-3 o/c
                      2-1 0.26v drop
                      2-3 0.26v drop
                      3-1 o/c
                      3-2 o/c
                      Camera is indoors, next time im out i'll bring it and take a picture of underside.
                      The brown/tan glue is just residue, I have cleaned it off already (when removing the diode for testing). Perhaps I should use some sort of chemical to remove the residue also?
                        That diode is fine.
                        Now check 5.3V diode.
                        • bbjunkie
                          • Dec 2011
                          • 301
                          0.713v drop one way and open circuit the other
                            A bit high but might just be a silicon diode.
                            Okay, post a picture of the SMPS controller and read off the part # if possible.
                            • bbjunkie
                              • Dec 2011
                              • 301
                              Hi tom66,
                              Extremely difficult to read the numbers on the controller IC
                              Looks like:
                              LT 723
                              082269CP
                              Still having focus problems with the camera, got some better pics though.
                              ZD1 was removed for testing when this was taken, and the two main caps were also removed to recheck and gain access to other components.
                                Test R43 and the other pink resistor.
                                eta- R24 too.
                                Not getting any hits for that part #, double check it with a loupe or 10X mag.
                                • bbjunkie
                                  • Dec 2011
                                  • 301
                                  R43 is 67.6k ohms and the other is 2 ohms, which tallys with their markings.
                                  I was using an illuminated desk magnifier to read the controller IC, even after cleaning it's almost impossible to read. Will try again when I go inside.
                                  • bbjunkie
                                    • Dec 2011
                                    • 301
                                    The other resistor I cant recall the value, but I tested it yesterday and it was ok.
                                    The part number of the controller is OB2269CC
                                    Attached extract from datasheet
                                      Okay, check Vdd (pin 7) relative to GND (pin 1). It should measure from about 16.5V to 36V. More detailed datasheet here:
                                      • bbjunkie
                                        • Dec 2011
                                        • 301
                                        Jumping between approx. 12v and 16v looks like it could be DC with lots of ripple. Tried on AC setting but not getting a proper reading.
                                        Haven't got my isolating transformer yet so cant put the scope on it.
                                        Jim
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • FiguringITout
                                          MSI Raider GE75 - Not posting, probable dead CPU
                                          by FiguringITout
                                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                          07-25-2024, 07:27 AM
