Technika LCD19DVDID dead
+ More Options
Posts
    Re: Technika LCD19DVDID dead
    Originally posted by bbjunkie
    Gate resistor - if that's the one you have marked as R? then it's 26 ohms, the diode to it's 11 o'clock checks fine in circuit (drop of approx 0.53 volts)
    I'm baffled then. What does the Vcc charging resistor measure as?
    • bbjunkie
      • Dec 2011
      • 301
      #42
      which one is that?
        which one is that?
        Connects from HV to Vcc cap.
        Also check the Vcc and main winding are both nearly s/c. If it's not, then the transformer has failed.
        • bbjunkie
          • Dec 2011
          • 301
          #44
          In your diagram, is that the one to the right of startup cap?
          Excuse my stupidity
            Excuse my stupidity
            Yep.
            If it's too high of a value the controller won't startup properly.
            As you've got an unstable Vcc, something is not charging up that capacitor once the supply starts up.
            • bbjunkie
              • Dec 2011
              • 301
              #46
              Resistor is 1.55m ohms and in spec
              Transformer measuring 1.2 ohms
              • bbjunkie
                • Dec 2011
                • 301
                #47
                When I measure from -ve on main cap to charge resistor end nearest diodes I get 0vdc 0.05vac and when I measure the other side of resistor i get 333 - 336 vdc
                  Sounds right. I have no idea what to suggest next; everything *seems* in order, there are no component failures, but it's still not working. There's the vague possibility the controller is dead, but you'd need a scope to double check.
                  • bbjunkie
                    • Dec 2011
                    • 301
                    #49
                    The learning curve just got steeper!
                    Ok, well im ordering that isolating transformer on Tuesday so it'll have to wait til then.
                    Hopefully i've another telly coming tomorrow to keep me busy :-) (with intermittent shutdown)
                    Anyway, thanks for your time, I really appreciate it. It's been a real learning experience.
                      Intermittent shutdown. If it's a Vestel, I wish you good luck: they are nasty supplies. I had one with the very same fault. I've tried to repair 3 17PW22/17PW15 series supplies so far; every attempt has ended in me buying a new one (luckily I've now found a cheap source for them.)
                      I'm glad to help. It's nice to pass on experience. Almost all of these tests I've asked you to do have been passed on from other members of this forum and others. I don't have a formal education in any of this stuff.
                      • bbjunkie
                        • Dec 2011
                        • 301
                        #51
                        It's a JVC LT-32A61SJ
                        Will start a thread when it arrives
                        Hopefully it wont be too bad, because I can't find any service docs for it!
                        Actually it's not intermittent shutdown.. just checked again.. it's intermittent stuck in standby.
                          Okay, you look to be clear. JVC are a good manufacturer of TVs and they make most of their own stuff, they don't import Vestel crap. Intermittently stuck in standby sounds like bad caps but JVC use good caps, just look at this power supply...
                          http://www.lcdtvparts.co.uk/images/P1100905.JPG
                          Full of Rubycons.
                          And... Service manual:
                          Btw, where you find it? I've been looking for nice JVC/Sony sets to repair. They are beautifully engineered. Panasonic too; I repaired a Panasonic Viera Plasma (42") - top notch quality and awesomely overengineered. The Y-sustain had 40 something MOSFETs on it and the bulk capacitance on the Vs rail was more than 5,000uF(!!) spread across several boards. Of course full of Rubycon, Chemicon and Nichicon (quality) but only a few Panasonic caps, strange! Because of such a large capacitance, there was even a HV present indicator, which stayed lit when the caps were charged to more than about 40V.
                          • bbjunkie
                            • Dec 2011
                            • 301
                            #53
                            nice!!
                            Picked it up off eBay - probably paid a little more than it was worth as it has no stand or remote (where do all these remotes go!) but should get my money back and some beer money to boot.
                              nice!!
                              Very nice. In the end, a single shorted MOSFET brought it down. It cost me £50 which was pretty cheap for a 42" full HD set. Owner thought it was a power supply problem but 5 mins with the flowchart and I had isolated the Y-sus as being faulty, then noticed people on eBay were selling the FETs for these boards, quickly isolated it (there were 6 in parallel) and it worked, to my surprise! I added another one in before I sold it.
                              I sell no-name 32" LCD TVs for £100 or so, and a brand name one would go for around £130-£150, depending on condition. I wouldn't pay any more than £35 for a 32" name brand, because you take a big risk on there being more than the initial fault.
                              • bbjunkie
                                • Dec 2011
                                • 301
                                #55
                                Did ok then, got it for £34. Made him an offer of £30 and we met at £34 (plus shipping of 12 quid)
                                  Nice. Most TVs I see on eBay go for a lot more. Like about £100. I need to look more carefully for buy it now / make offer listings.
                                  • bbjunkie
                                    • Dec 2011
                                    • 301
                                    #57
                                    no you dont they are hard enough to find
                                    • bbjunkie
                                      • Dec 2011
                                      • 301
                                      #58
                                      Hello again
                                      I have spent the morning tracing the circuit and drawing a circuit diagram to see if it will help me understand the circuit better.
                                      What i've drawn has confused me a bit, I couldn't understand why measuring between the hot end of the charge resistor R24 (which is between HV and Vin on PWM controller) and -ve on the main cap is giving me 0vdc but yet measuring the other side was giving me 333-336 volts dc
                                      Turns out the legend on the pcb wasn't actually indicating the - leg of the cap.. there is another legend identical below the other leg. I had been making the measurement with respect to HV instead of hot ground.
                                      Now i've got the black lead on the correct pin of the cap, i'm seeing 333 volts DC rock solid on the HV side of R24. On the other side of R24, in circuit im seeing a very jumpy voltage varying from about 12vdc to 18vdc or so (impossible to measure the exact fluctuation as it changes so fast) but with the controller end of the resistor out of circuit the voltage is a steady 285vdc when measured there.
                                      From this can we deduce that the controller is causing the wild fluctuation in DC voltage and if so, is it normal?
                                      I notice a very small surface mount decoupling cap on the Vin line - could it be faulty?
                                      • bbjunkie
                                        • Dec 2011
                                        • 301
                                        #59
                                        After shorting G to S I'm seeing a voltage drop of .5v slowly dropping to .3v between D and S
                                        Does this mean it's faulty?
                                        It's faulty now alright!
                                        Dropped my capacitor discharge resistor into the primary side while attempting to discharge the main cap. There was a crack as one end hit the MOSFET and now the test (out of circuit) shows a constant .5v drop
                                        Will get one ordered and continue this in the new year.
                                        Happy new year guys
                                        Jim
                                          Sorry, I've been busy over new years with limited internet access. I've said it before; I think the problem is your power supply isn't getting enough power to continue running once started up. Causes include overload on the output, shorted diode, shorted cap (rare), open MOSFET (rare), bad controller IC, or even a bad transformer (rare), among others.
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
