Re: Technika LCD19DVDID dead
Remove the Vcc/startup cap and check it if you can. Sounds a lot like you have a bad startup cap. 12V might be enough for the chip to cut out (threshold is 11.5V for a very similar chip.)
If you can't test it, just replace it. They are cheap anyway and no need to use a low ESR one, a general purpose cheapie will do fine.
eta - Just noticed the datasheet specifies an over-voltage threshold of about 23-25V, so this should be a maximum, not 32V.
