Element ELCHW261 White screen
  • IRace93
    Resorceful Nub!
    • Dec 2011
    • 44
    Picked up a chepo Element ELCHW216 26" LCD and if I can save it I wanna use it as a Second Monitor!
    It powers up but goes just to white screen. removed the back and there dosent appear to be any suspect caps jumping out at me or any traces of heat on any of the boards the one fuse tests good. I cant verify sound I did hook the hdmi up and attempt to scroll the sorce button but cant tell what input I am on???
    any Ideas on what to look at first?
    I assume this is a shared board with other Cheapo Tvs??
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Element ELCHW261 White screen
    Sometimes these LCDs have a t-con (timing control) board. From the logic/main board, follow the cable upwards toward top of the LCD. Sometimes the t-con is underneath metal shielding.
    On t-con, there may be a SMD fuse and it could be open.
    If this LCD doesn't have a t-con, then there will be a panel board that runs the entire length of the TV. On that panel board, there may be a fuse as well.
    PS. In the future, we generally want pics as close to 2000x2000 as possible. 640x480 is too small to see any detail.
    Also, we want an overall backside picture of the entire TV so we know how the boards are connected and their relationship to each other. Then we want a close up of each individual board.
    --- begin sig file ---
    --- end sig file ---
    • IRace93
      Resorceful Nub!
      • Dec 2011
      • 44
      sorry i really dont know how run my camera to its potential!
      • IRace93
        Resorceful Nub!
        • Dec 2011
        • 44
        Anyone???
        • PlainBill
          • Feb 2009
          • 7034
          I was waiting for you to report on the results of following retiredcaps advice.
          PlainBill
          • IRace93
            Resorceful Nub!
            • Dec 2011
            • 44
            well I dont see a sepate board at the top of the TV? is it on the Green board under the metal sheild? or are you talking about where that black cable with the colored wires runs to the top of the set? theres a Tiny board up in there?
              That may be the board in question. It's usually bigger than a tiny board though as it has logic on it for decoding LVDS signals and providing the correct signals to the LCD panel. Are you sure you aren't missing it? Could be hidden under some shielding etc...
              • walking
                • 28
                • usa
                I've "repaired" two of these with white screens. Both had loose cables @ the screen from the mainboard. Got them from a big box store returns liquidation auction for $20 for 3 of them. I have another with white screen but the cables are fine and continuous...so tracing away at it.
                See pic, other end of circled cable was loose on two machines.
                • squachy
                  • Jul 2012
                  • 12
                  How do you know if it is loose, and then if it is how do you tighten it back up so it functions properly?
                  I am new to electronics so I am really wanting to learn and am having this issue as well.
                  • killian6pk
                    • Apr 2010
                    • 502
                    What he was talking about was not loose so much as not pushed in all the way. Be careful when pushing it in, support the underside of the board with your other hand. Circuit boards if flexed too much can break or traces can break. If this does not fix your tv then start a new thread (on the main troubleshooting page) and take good, focused top down pictures of all of your boards front and back. Also take one picture of all of your boards hooked together (how it looked when you first took the back off). The pictures need to be as close as possible to 2000 x 2000 dpi, but not exceeding that. We want to be able to see the writing on the boards.
                    Have you ever stopped to think and then forget to start thinking again?
                    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
                    • squachy
                      • Jul 2012
                      • 12
                      Maybe these pictures will help (They are large on my computer. I'm not sure how they will translate)
                      When pushing it back in, is it more of a downward push like towards the bottom of the tv? or inward towards the screen?
                      • harp
                        White screen repairs
                        by harp
                        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                        05-13-2024, 03:43 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • EazyBone
                        Sharp LC-65Q620U White Screen
                        by EazyBone
                        Another TV topic!!
                        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                        08-21-2024, 12:56 PM
                      • hcinne
                        Dell G15 ryzen edition black screen 2 amber 1 white
                        by hcinne
                        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                        07-23-2024, 07:56 AM
                      • Chrissygizmo
                        Panasonic TX-48CX350B backlights but white screen , blank screen
                        by Chrissygizmo
                        Hi all, I’ve got a problem I hope someone can help me fixi.
                        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                        01-11-2025, 03:18 PM
