Sharp Aquos 32"
+ More Options
Posts
  • rigeback
    • Mar 2011
    • 421
    • Malta
    Sharp Aquos 32"
    I found this TV at the Dumpster today and seeing it had never been opened brought it home to try it out, unfortunately I didn't find the remote!
    The power supply seems to be working okay as with the back lights and sound although when I tried to enter setup manually theres nothing.
    I have not hooked it up to the sat decoder as yet but I'm sure they wouldn't have thrown it away if they had a picture!
    I am considering to hook it up the a PC first as soon as I've down loaded more info from Sharp, would appreciate any good recommendations as where to start as this is my first plasma!!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Sharp Aquos 32"
    Look at your last picture with the logic board. CCFL in LCD panel.
    Anyway, hookup a source and report back what you find.
    --- begin sig file ---
    --- end sig file ---
    • rigeback
      • Mar 2011
      • 421
      • Malta
      Re: Sharp Aquos 32"
      I tried hooking it up to my sat decoder via SCART cable and I have sound but no picture, I do not have an antena with the single M/F plug, will try to the PC later but I want to read the manual a bit reagrding firmware etc.
      • PlainBill
        • Feb 2009
        • 7034
        Re: Sharp Aquos 32"
        It's an LCD, not a plasma.
        PlainBill
        • rigeback
          • Mar 2011
          • 421
          • Malta
          Re: Sharp Aquos 32"
          Hi Bill. Yes, and its a 26" as I just noticed, looking at the manual just now, what do you think wrong with it??
          • rigeback
            • Mar 2011
            • 421
            • Malta
            Re: Sharp Aquos 32"
            Well the TV has definetly got a picture problem as it didn't show the desk top of the laptop connected two ways, some part will have to be changed, a web search reckons the inverter needs new parts but think this one has an easier solution, hopefully.
            • rigeback
              • Mar 2011
              • 421
              • Malta
              Re: Sharp Aquos 32"
              Hi guys, any info as to where to get started here would be great, could it be the T-con because the PSU seems to be okay although I will recheck the voltages before I go a head and dissassemble the unit, power stays on normal and I can listen to CNBC, the back lights are working but I can't enter setup or do factory reset. I found a good data sheet for the boards, please see attached.
              • retiredcaps
                • Apr 2010
                • 9271
                Re: Sharp Aquos 32"
                Post a picture of the t-con. If there is a fuse, check to see if it is open. A good fuse should measure less than 1.0 ohms.
                • rigeback
                  • Mar 2011
                  • 421
                  • Malta
                  Re: Sharp Aquos 32"
                  Yes I have been looking for that F1 fuse but I don't see it on this board or the T-con, theres a bunch of FB and FL type fuses but they check out ok so far, theres some new pics but not so clear of the T-con.
                  This type of control board has incorporated most of the t-con parts it seems.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    Re: Sharp Aquos 32"
                    Looking at the last pic in the first post, it looks like Sharp decided to combine the t-con and the mainboard on one PCB for some stupid reason (cost saving?)
                    I marked it in red in the attached picture. The bundle of traces going from the chip with the heatsink on it (CPU?) to the chip above it is probably where "normal" LCD TVs would have a cable running to a seperate T-Con board mounted at the top center of the panel. But instead, it's all on the mainboard, so if one thing fails, the whole mainboard has to be replaced if it can't be fixed.
                    Good to know. I'll stay away from Sharp LCD TVs then. What a POS. [/rant]
                      master hoarder
                      • May 2008
                      • 12170
                      • Bulgaria
                      Re: Sharp Aquos 32"
                      FB is probably an abbreviation for Ferrite Bead (in other words, an inductor).
                      FL - Ferrite Inductor?? I'm guessing though.
                      Looks like Scenic is right - this TV combines the t-con with the video board. If you look at the 3rd picture in post #9 (this one), you can see test points VGH35V and VGL-6V in the lower right corner near the large connector and the big Sharp microchip. VGH and VGL are names usually associated with the secondary step-up rails on a t-con. My guess is that VLS15.6V is the primary step-up rail.
                      Like other LCD monitors we've tested before, measure the resistance between VLS15.6V and ground, VGH35V and ground, and VGL-6V and ground. I think you already know the drill here - use 200 Ohm scale (the lowest one).
                      Also measure the voltage on the VLS15.6V rail. Should be 15.6V if everything is right (or if the label on the circuit board is correct).
                      • rigeback
                        • Mar 2011
                        • 421
                        • Malta
                        Re: Sharp Aquos 32"
                        Hey Momaka, good to have you trouble shooting again! Lets hope I get this one right.
                        Anyways these are the resuls of the tests; VLS 15.6V seems good with 15.55 Volts, [B]VCC1.5 v = [B]100 Ohms and with power on read 1.49 Volts. VGH 35V on the otherhand has no power and no resistance.
                        VGL 6V also has very low resistance at 2K 5.0 Ohms and a negative power reading -5.97 Volts.
                        I will try see what VGH 35V connects with.
                        • rigeback
                          • Mar 2011
                          • 421
                          • Malta
                          Re: Sharp Aquos 32"
                          VGH35V connects with Q8408 and D8408 and further I did not find a connection
                            master hoarder
                            • May 2008
                            • 12170
                            • Bulgaria
                            Re: Sharp Aquos 32"
                            VLS15.6V and VCC1.5V are good.
                            The voltage on VGL-6V is good as well. I'm not sure the resistance you measured is correct, though. 5 Ohms would suggest that rail is supplying over 1 Amp of current, which is not possible since these secondary step-up rails are low-current. Anyways, since the voltage is correct, I'm inclined to think everything is fine with that rail.
                            What do you mean by no resistance? Is the multimeter showing 0.00 Ohms or a "1" (or "OL") on the left side of the screen?
                            - If "1" (or "OL") on the left side of the screen, that's fine.
                            Also, VGH35V will likely measure close to 35V, so with a manual multimeter make sure to use the 200V scale and not the 20V scale when measuring the voltage. Otherwise you will get a "1" or "OL" on the left side of the screen.
                            If you still don't get any voltage even after trying that, try measuring the voltage on all of the pins of Q8408.
                            Lastly, what is the part number on IC8402?
                            • rigeback
                              • Mar 2011
                              • 421
                              • Malta
                              Re: Sharp Aquos 32"
                              Yes you caught me out again, set the tester on 200V and sure enough 35V is present on
                              VGH35V and yes the "1" was there for resistance test, IC8402 has "DCQG" printed on top in large letters, the outer pins have 30V and the center pin has 35V.
                              I found a good pdf manual that I wanted to upload but it won't load even so it only 5MB.
                              Compliments of the season and the site looks great with the Christmas lights!
                                master hoarder
                                • May 2008
                                • 12170
                                • Bulgaria
                                Re: Sharp Aquos 32"
                                Looks like all of the major t-con voltages are there then. So t-con is likely working fine.
                                There are some other voltages not on the t-con that are probably worth checking, though. These are (using the same 3rd picture in post #9 as a reference) test points:
                                BU 3.3V, B+5V, BU1.8V, B+3.3V, and VCC3.3V
                                • rigeback
                                  • Mar 2011
                                  • 421
                                  • Malta
                                  Re: Sharp Aquos 32"
                                  All the tests were good except for BU 1.8V and BU+1.8V lines seems to have a problem there is only 1.78 Volts on these test points so I think one of the IC's might be bad.
                                  I cross checked IC 1756 and find Pin1=1,21V Pin3=3.04V Pin4=3.22
                                  Pin5=1.79V
                                  I also tested IC 1702 ; pin1=1.21V pin3=3.04V pin4=3.22V and pin5=1.79VOn IC 1726 pin2=8.16Vas with pin3=8.16V so some where in between theres a malfunction if this 8 Volt line supplies the screen?
                                  This link might might help trouble shoot the problem.
                                  http://www.scribd.com/doc/67258779/S...urse-English-1
                                    master hoarder
                                    • May 2008
                                    • 12170
                                    • Bulgaria
                                    Re: Sharp Aquos 32"
                                    No, those voltages are right. BU1.8V should be 1.8v. 1.78V is close enough.
                                    I will look tomorrow for other things to look at. Seems the t-con is working fine.
                                    • rigeback
                                      • Mar 2011
                                      • 421
                                      • Malta
                                      Re: Sharp Aquos 32"
                                      Sorry I got side tracked thinking I was looking for an 8V signal due to the way its printed on the board, I was reading that this problem could be related to the HDMI system?
                                      • rigeback
                                        • Mar 2011
                                        • 421
                                        • Malta
                                        Re: Sharp Aquos 32"
                                        Tried connecting the PC again with softMCCS http://www.entechtaiwan.com a good little program to learn what the software is doing inside the TV but it does not see the LCD and its now obvious that there is no power at the serial connector nor SCART / HDMI connectors, this area is dead! Need to find the supply point??
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • jonah1024
                                          Sharp Aquos LC-40UG7252E LCD TV burn in?
                                          by jonah1024
                                          Hello!
                                          I'm a few days old into this TV screens repair universe so please bear with me.
                                          Recently, and all of a sudden my 40ā€ 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                          - I did a factory reset as well...
                                          07-16-2024, 04:23 AM
                                        • klassic
                                          Sharp Aquos LC-60LE635E three blinks
                                          by klassic
                                          Hi community,
                                          I will describe my problem with a TV in those short following terms to be the most precise :
                                          What i have :
                                          power board DPS-162KP-1
                                          main logic board QPWBXF733WJN2
                                          symptoms :
                                          white led light logo at startup,
                                          after 2 minutes, blinking 3 times a row, repeating
                                          no backlight (and apparently no picture, checked panel with flashlight)
                                          no startup sound
                                          powerboard investigations :
                                          1-2 PNL : 0v
                                          3-4 GND
                                          5-6-7-8 UR : 13.15v
                                          9-10-11-12...
                                          10-24-2023, 01:39 PM
                                        • foxyUK
                                          Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                          by foxyUK
                                          Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                          The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                          There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                          10-22-2024, 10:27 AM
