Samsung S42AX
  • xstatic
    • Dec 2011
    Samsung S42AX
    I have a Samsung HP-S4233 42 inch plasma tv and it displays solid fine bright multicolored colored lines throughout the screen. There are no free spaces anywhere. The tv images appears very faintly behind this image. All Inputs display the lines whether there is no signal or not. As soon as the tv is turned on the lines appear.
    I heard a do it yourself solution was to replace a group of capacitors but the ones suggested look fine. Any suggestions. even knowing what board to replace would still be cheaper than a technician coming over.
    Sound comes in fine.
    Any help would be appreciated.
    Oh yes, the TV was manufactured in 2006. Should I just junk it?
  • lcdman
    TinkerTech
    • Nov 2010
    • 232
    • U.S.A.
    Re: Samsung S42AX
    Hello & Welcome Aboard,
    I found a service manual but its not free unfortunately. Also found some things on Ebay. Are you sure you have the full model number for this HDTV? Good luck with your Tv.
    http://www.servicemanuals.net/Servic...1/results.aspx
    http://www.ebay.com/sch/i.html?_from...All-Categories
    Take Care,
    lcdman
    Last edited by lcdman; 12-14-2011, 08:36 PM. Reason: didn't spell check before posting
    • cadiman
      • Mar 2010
      • 397
      Re: Samsung S42AX
      The first picture is the hallway runner in my mom`s house.
      The second picture looks like a plasma tv with issues on the main video board. (signal)
      I would look at any surface mounted caps on the board I noted above.
      Does it get worse/better hot or cold?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: Samsung S42AX
        You can't tell by looking.
        Mann-Made Global Warming.
        - Dr Seuss
        • xstatic
          • Dec 2011
          Re: Samsung S42AX
          I heated the caps with a blow dryer and there was no difference in the picture. No caps seem to be bulging so that makes it hard. Might have to replace a whole board.
          • xstatic
            • Dec 2011
            Re: Samsung S42AX
            Thanks for the link icdman for the manuals. I tried here but too many..
            This is a good link though
            http://www.eserviceinfo.com/fulltext.php?pagetogo=3
              09-07-2024, 05:50 AM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              Sadly it has vertical lines at the left and one line in the middle-right.
              I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
              I have factory resetted the TV as well but also with no luck.
              I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
            • Rubenlily
              Samsung QE50Q67TAU - horizontal lines
              by Rubenlily
              First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
              I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
              I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
              I'm no expert but I've done the tape...
              08-16-2023, 01:12 PM
            • jeyoung12
              Samsung QN50Q60t lines on screen
              by jeyoung12
              Hi all
              I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
              My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
              This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
              It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
              So....i don't know what end of the C ribbon to work with...
              02-26-2024, 10:38 AM
              09-06-2024, 11:40 PM
