how to test a Voltage Regulators
  • mcross
    • Sep 2011
    • 201
    Hi guys, how do i test a (278RA05) 2A Output Low Dropout Voltage Regulator
    Thanks for any info
  • PlainBill
    • Feb 2009
    • 7034
    Re: how to test a Voltage Regulators
    Thanks for any info
    I just measure the output voltage. If it isn't correct, I check the input voltage. For more exhaustive tests, look up the datasheet - they often include test circuits.
    PlainBill
    • Scenic
      o.O
      • Sep 2007
      • 2642
      looks to be a 7805 variant with an extra pin for adjusting the voltage or disabling the output.
      1st pin: input
      2nd pin: output
      3rd pin: GND
      4th pin: either voltage adjustment or output disabling
      if the 4th pin isn't connected to anything, you should see 5V DC on pin 2
      • mcross
        • Sep 2011
        • 201
        thanks, will check it now
        • electron_jj
          Panasonic TH-L42D25A checking the PSU output voltage
          by electron_jj
          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
          08-29-2021, 08:13 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • bauto601
          KDM 480W PSU upgrade succes! (opinions?)
          by bauto601
          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
          A "nice" YoungYear unit? - Badcaps
          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
          12-26-2023, 03:05 PM
        • redbaron1007
          Yamaha HTR-3065 No power/No Standby
          by redbaron1007
          I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
          S9 13.7V
          Pwr Ry 0V
          AC Det 9.1V
          Mgnd 0V GND
          The two pins on the transformer for the operation...
          09-12-2024, 03:04 PM
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
