Panasonic Plasma
    Panasonic Plasma
    How hard is it to replace boards in a TH46PZ85U PANASONIC PLASMA?
    Do you guys know of any pictures that i could look at to see what screws need to come out?
    thanks
    Re: Panasonic Plasma
    You just take out all of the screws from the back panel, and remove it. There will be a lot of them. The harder part is determining what board(s) are bad. It is not uncommon for more than one board to have problems in a Panasonic plasma.
      thanks
      That question doesn't bode well. Usually the screws that hold the back in place are indicated by arrows in the metal or plastic. Please be aware that plasma TVs operate at high voltages and currents. 385 VDC at 3 Amps can seriously alter your perspective on life.
      The service manual is at Elektrotanya. You might also want to search that site for Panasonic Training Manual.
      PlainBill
        well i have 2 boards one is a Power supply one is the board where all devices get connected to! so the back pannel comes off, then thats it , hmmm i guess ill find out then just didnt want to attack it without knowing something!
          >>....just didnt want to attack it without knowing something!<<
          Oh, this doesn't sound good....
          veritas odium parit
            What could possibly go Wrong? I have a Philps Screw driver!
              >>I have a Philps Screw driver!<<
              THAT's the Problem! You have the wrong type.
              You need a Phillips screwdriver...
              "Danger! Will Robinson! DANGER!"
              veritas odium parit
                Well there was 25 screws to back panel of tv. Then the power board had 6 screw. And 8 connection wires. Then the device board had 6 screws. And 8 wire connections and it was all philps head screws. Plus. Nowtv. Does work again
                  So put the Doubting Thomases in our place and tell us what you did to fix it. Brag a little.
                  PlainBill
                    Brag hmmm I don't know how to brag well I took the tv apart all 25 philps screws!! Replaced the power board then put it back together..
