Panasonic Plasma
  • jtechie
    • Dec 2011
    • 7
    Panasonic Plasma
    How hard is it to replace boards in a TH46PZ85U PANASONIC PLASMA?
    Do you guys know of any pictures that i could look at to see what screws need to come out?
    thanks
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Panasonic Plasma
    You just take out all of the screws from the back panel, and remove it. There will be a lot of them. The harder part is determining what board(s) are bad. It is not uncommon for more than one board to have problems in a Panasonic plasma.
    • PlainBill
      • Feb 2009
      • 7034
      thanks
      That question doesn't bode well. Usually the screws that hold the back in place are indicated by arrows in the metal or plastic. Please be aware that plasma TVs operate at high voltages and currents. 385 VDC at 3 Amps can seriously alter your perspective on life.
      The service manual is at Elektrotanya. You might also want to search that site for Panasonic Training Manual.
      PlainBill
      • jtechie
        • Dec 2011
        • 7
        well i have 2 boards one is a Power supply one is the board where all devices get connected to! so the back pannel comes off, then thats it , hmmm i guess ill find out then just didnt want to attack it without knowing something!
        • Toasty
          • Jul 2007
          • 4171
          >>....just didnt want to attack it without knowing something!<<
          Oh, this doesn't sound good....
          veritas odium parit
          • jtechie
            • Dec 2011
            • 7
            What could possibly go Wrong? I have a Philps Screw driver!
            • Toasty
              • Jul 2007
              • 4171
              >>I have a Philps Screw driver!<<
              THAT's the Problem! You have the wrong type.
              You need a Phillips screwdriver...
              "Danger! Will Robinson! DANGER!"
              veritas odium parit
              • jtechie
                • Dec 2011
                • 7
                Well there was 25 screws to back panel of tv. Then the power board had 6 screw. And 8 connection wires. Then the device board had 6 screws. And 8 wire connections and it was all philps head screws. Plus. Nowtv. Does work again
                • PlainBill
                  • Feb 2009
                  • 7034
                  So put the Doubting Thomases in our place and tell us what you did to fix it. Brag a little.
                  PlainBill
                  • jtechie
                    • Dec 2011
                    • 7
                    Brag hmmm I don't know how to brag well I took the tv apart all 25 philps screws!! Replaced the power board then put it back together..
                    • jm1234
                      Panasonic plasma TX-P42ST50 - 6 blinks
                      by jm1234
                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                      I checked that board for any obvious faults...
                      05-22-2024, 06:59 AM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      I happened several times, in the search for help from the web, to consult this very interesting forum.
                      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                      Having said that I come to the gist of my post on the forum as the title suggests.
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • Alicat
                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                      by Alicat
                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                      Model number is TH-50PZ85U
                      Power comes on and the red power light stays on solid.
                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                      I also hear a few clicks.
                      I also think my parents said there was a thunderstorm and the TV failed after that.
                      Section 6 in the service manual talks about power and no screen,...
                      10-30-2024, 10:09 AM
                    • Lintesir
                      Panasonic P42S30 Plasma - Pink sparkles
                      by Lintesir
                      My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                      There is about a 5cm high region at the top without any sparkles,...
                      07-26-2024, 03:16 AM
                    • badcappo
                      Dead Panasonic Viera TX-P65STW50 Plasma TV
                      by badcappo
                      Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                      Diode type G972s6 - D101 with a short
                      Mosfet 06N90E - Q301 shorted
                      Fuse T5AH 250V - F103 blown
                      Diode D301 shorted
                      Relay DG1U-17VDC II - RL001 blown
                      I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                      11-24-2024, 11:27 AM
