Replacing Cracked LCD on 32" Proview???
  • Paul678
    • Nov 2011
    • 402
    This is a Proview 3200 I believe. Someone gave it to me, because
    someone banged into the front screen, and cracked the glass
    badly, and now when you turn it on, there are white and black
    patches following the cracks across the screen, with horizontal, multi-colored lines up and down. Pressing the buttons does not change the
    display.
    So I'm considering buying this replacement LCD:
    http://www.ebay.com/itm/370556029200...84.m1438.l2649
    But I'm not sure my T871015.01 inverter board works:
    http://www.ebay.com/itm/150693633714...84.m1438.l2649
    And I'm not sure my V320B1-C is ok:
    http://www.ebay.com/itm/170731604365...84.m1438.l2649
    How do I test the inverter and the V320B1-C?
    Thanks for your advice.....
  • Paul678
    • Nov 2011
    • 402
    Re: Replacing Cracked LCD on 32" Proview???
    Some more info:
    One one hand, I'm thinking the inverter and the V320B1-C are
    still ok, because the LCD screen is a thick 1 inch, and since
    the blow to the front was clearly around the center of the
    screen, these boards should have been well insulated from the
    force. Also, the fact that the screen still lights up and displays
    bright white, and other colors, is a good sign.
    OTOH, the bad sign is that the picture never changes, and the
    buttons don't affect it, and I cannot bring up even just a menu.....
    Thanks for any help......
    • randtek
      • Oct 2011
      • 280
      • US
      It is not uncommon for a broken LCD panel to have no detectable picture information. It just depends on how it is broken. The rest of your TV is probably fine.
        You've got to weigh up the cost. Most LCDs with cracked screens get binned; it's not often economical to replace the LCD. Sell the parts, and buy a TV with bad caps or something to fix.
        • Paul678
          • Nov 2011
          • 402
          True. But I've looked on Craigslist and ebay, and I figure I could sell a used 32"
          LCD for about $200 or so. Most people want about $100 (this includes shipping) for a used, working LCD of this type on Ebay.
          But you can make a "best offer" for less.......I may try to lowball the guy....
          $100 profit isn't much, but OTOH, is it worth the hassle of selling the parts through ebay, and all the packaging you have to do?
            It's your decision of course, but I'm not sure you could sell one of those for $200. I usually sell a 32" LCD for £80-100, about $130 - 160.
            • Paul678
              • Nov 2011
              • 402
              You're in England? At least in my city, they are going for a bit more, with
              some people asking more than $200.
              But assuming I decide to sell the other parts, about how much do you think I could get for them, assuming everything else in the TV works?
                Possibly £30 for the main board, £30 for the PSU, £30 for the inverters and £3 each for the bulbs. Plus the remote control, if you have it.
                • Paul678
                  • Nov 2011
                  • 402
                  What are the "bulbs"?
                    The CCFL backlight bulbs - there are around 10-12 in a 32".
                    • ipatch
                      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                      by ipatch
                      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                      08-24-2024, 02:36 PM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • jean luc ferre
                      acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
                      by jean luc ferre
                      on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
                      i tried the hard reset, cmos reset, changing the ram without results.
                      in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
                      The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
                      but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
                      Yesterday, 03:54 PM
                    • mmccomputer
                      problem with replacing lcd screen
                      by mmccomputer
                      I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                      otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                      If anyone has any information on the subject...
                      12-15-2024, 03:44 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
