Re: Polaroid TLX-04244B
TLX-04244b the screen turns on for a second and then buzzes and shuts off.
I have fixed 2 of these now both times they just had bad bulbs. same 3 bad bulbs in both TV's. replace those and you are good to go..
If you really watch the screen when it comes on, you can see a shadow across the screen where the bad bulb is.
Polaroid TLX-04244B
Does anyone have the service manual for this model TV (polaroid tlx-04244b). I have a seven blue light blink code.?Leave a comment:
TCTV - That post was 2 years old - wouldnt hold your breath for a replyLeave a comment:
So I got home today and truned on the t.v so I could see the bad bulbs and it truned on but the light slowly shut off from right to the left and I started smelling something like electrical components burning. I immediately unplugged the t.v and inspected it and found this. So do you think the master board is bad now or what could have caused this, i;m kinda scared to plug it back.
I have the same problem. I dissembled tv and found 3 bulbs out which is what was shutting inverter down. I tried cleaning ends and moving around bulbs to troubleshoot. When I turned tv back on I smelt something and found the same burn on the master board plug. Now I have no backlight at all, Found out I cracked a ccfl and must of overloaded something. Did you find a fix for this (Master board replacement)?
Please let me know what you found.
Thank You...
tctvLeave a comment:
You can use similar size bulbs from a TV with a cracked panel, you may have to solder them in but worked for me in the past..Leave a comment:
Where did you find the replacement ccfl bulbs for your TLX-04244b, and what size are they if I can find some locally.
Thanks..Leave a comment:
I had the same problem with this tv (TLX-04244b) I found 3 bulbs out and 1 flickering, (seemed like the buzzing was coming from the flickering bulb). After swapping bulbs around I noticed the same smell and smoke (from same HV plug on inverter board) and after closer inspection noticed I cracked a bulb. Must need all bulbs in / good or bad because now Tv backlights just flicker a little bit. Thinking I fried something...Leave a comment:
That is corect, there is 3 second timing circuits that detect if the lamp fired up and stay conducting, open connection (lamp not connected), over current, the inverter circuits will shutdown, it only take one bad lamp to shutdown the inverter circuits.Leave a comment:
What I found out with my LCD tv if the any of the ccfl lights goes out, the inverter board shuts down within a few seconds of starting. This was the case with my TV. One bulb was out causing this issue. It is a project to tear apart though. As you can see from the pic, there are 18 bulbs and one in the middle is out. You can also tell by the darkness of the LCD bulb.Leave a comment:
You should upload the pictures of the boards used in your TV first since we do not have the set in front of us to see what you have to start with.Leave a comment:
Still looking for help with the POLAROID TLX-04244B. Has anyone found a fix for this TV backlight problem, mine has 2 separate inverter boards.Leave a comment:
Has anyone been able to figure out the problem with this polaroid tlx-04244b tv.Leave a comment:
It was 12 months ago - perhaps pm the original poster and ask if he got it fixed.
Looks like he needed some bulbs and bought the onverter as well.
You could do some of the early testing as per the thread and revert back if you get stuck.
Welcome to the forum-
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attachm...1&d=1290283049
https://www.badcaps.net/forum/attachm...7&d=1280167246
It will be useful if you can say a bit about yourself - skills tools etc.Leave a comment:
Hi - I have the exact same model TV with the exact same problem. Can't really determine from the posts what ultimately ended up being the problem here. Were the inverter boards bad, was it faulty CCFL's, or both? Were you able to actually fix the problem? Wondering if the set is worth fixing? Any help would be greatly appreciated. ThanksLeave a comment:
I just bought this http://www.ebay.com/itm/180694085505...#ht_1794wt_895
hope they work, I think i'm going to have to solder them in.
I would sell it faulty, and buy an easy to repair TV like one with bad caps. I can get a TV with bad caps fairly easily, for around £30-40.Leave a comment:
hope they work, I think i'm going to have to solder them in.Leave a comment:
Ok so i'm talking to this ebay seller that sells cccfl's and eefl's. He said I should put eefl's in. But how do I know for sure what I have now? I posted a picture of the eefl he sent me. And the other picture is what I have now.
Here the EEFL it would't upload here. http://s1212.photobucket.com/albums/...nt=TheEEFL.jpgLast edited by tom66; 12-03-2011, 03:27 PM.Leave a comment:
Here the EEFL it would't upload here. http://s1212.photobucket.com/albums/...nt=TheEEFL.jpgLast edited by 2011srg; 12-03-2011, 03:19 PM.Leave a comment:
So I got home today and truned on the t.v so I could see the bad bulbs and it truned on but the light slowly shut off from right to the left and I started smelling something like electrical components burning. I immediately unplugged the t.v and inspected it and found this. So do you think the master board is bad now or what could have caused this, i;m kinda scared to plug it back.Leave a comment:
by Chivo77hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
1- After receiving power SIO_SLP_S0# goes high and never changes.
2-every...07-03-2025, 09:20 AM -
by ChrissygizmoHi all, I have a polaroid p49fn0038k, I originally thought the problem was just a straight forward backlight replacement, however this isn't the case..
When I power it up, the backlights flash on for a split second, I've tested the backlight strips and all are fine, I can see the polaroid symbol on the screen using a torch light....
Thanks in advance11-10-2022, 10:30 AM -
by crazycavanpolaroid TQLHD24PR004 no power
hi, my tv no longer starts like dead, no standby led
motherboard : MS36639-ZC01-01
panel : V236BJ1-P01
flash spi: GD25Q64
need usb firmware or to reprogram -
by snimmitsGood afternoon,
I have a Polaroid P43D300.
It shipped with WiFi and Bluetooth.
Two weeks ago, I ran through the first time installation.
This did a full reset and went through the first time setup.
Once complete, I went to settings > sound.
selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
search completes and doesn't find any devices.
I have tried everything I can think of.
Can someone provide... -
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... - Loading...
