Stupid DIYer, TV wasn't broken but it is now.
  • Slanter
    • Nov 2011
    So my TV, for the past two years, has been displaying amorphous dark blobs on the screen, that didn't seem to have any sort of pattern or anything, just a slightly darker section of the screen that would really only be noticable when watching something dark.
    Well I read some stuff about how that could be caused by dirt buildup either between the LCD and clear cover, or between the lamp and the LCD so I started to disassemble it to get to the LCD panel. I've replaced a lot of LCD's on monitors and laptops so I figured they'd be similar.
    So I get the whole cover off and get down to the LCD panel, which is just a big glass sheet with a handful of ribbon cables along the top going to 2 circuit boards along the top. My problem was that the ribbon cables were just glued to the circuit boards with some sort of adhesive, and when I lift the screen to try to get to underside without disconnecting the ribbons four of the ribbons peeled away from their seats... and now I have no way of reconnecting the ribbons, or even determining how to line the ribbon up right on its contact area. directly below where the still-connected ribbons are seated the TV shows kinda random colors, but the rest of it is black. Am I boned or can this actually be fixed?
    by the way, model of this TV is a sharp aquos lc-c3742u. Kinda old. All the previous LCD's i've dealt with just had a plug for any ribbons, but apparently sharp decided being able to replace an LCD screen easily wasn't a good idea.
    Re: Stupid DIYer, TV wasn't broken but it is now.
    It's not possible to fix it. The ribbons are welded on, you can try and apply pressure to them to fix it, but it will be a temporary fix at best.
    It's not possible to fix mura (unevenness) on LCDs, as the problem is inherent to the LCD, and has very little (nothing?) to do with the backlight or diffuser. It's a problem with the density of the liquid crystal in the panel.
    The LCD is replaceable, but it comes as a module - backlight and all - and will be very expensive.
    • chth96
      Is it possible bridging tiny broken trace
      by chth96
      When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
      cutting tiny trace.
      This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
      Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
      But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
      12-03-2022, 11:32 PM
    • ArchangelGabriel
      Aorus 17G YD laptop, broken display, could not switch to external monitor
      by ArchangelGabriel
      Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
      11-23-2023, 03:55 AM
    • corrize
      Resonator - quartz broken - how to find the same (same frequency) ?
      by corrize
      Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
      I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
      I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
      I'm searching another one for compare…
      Do you have an idea or another way for find the frequency of this resonator please ?
      (I did not found the manufacturer of this component ? And I did not found the...
      03-27-2025, 09:20 PM
    • Jidis
      Need T-Con Advice (Vizio P602ui-B3)
      by Jidis
      I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
      He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
      09-22-2025, 05:10 PM
    • emeskay
      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
      by emeskay
      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
      08-06-2024, 07:13 AM
