Sanyo DP 50747 50" plasma/Stopped working-No video
  • buntinre
    • Nov 2011
    My Sanyo DP 50747 50" plasma tv stopped working. No video, but will turn on the front green light and a relay will click, then shut off after 3-5 seconds. Not sure if audio works, I use a surround sound and not the internal speakers.
    -I removed the back panel and checked all 7 fuses on the various boards with my fluke 88 dvom. All checked out ok for continuity.
    -When you turn power on, Green LED on main power supply board blinks 5 times and repeats until tv automatically shuts down 3-5 seconds.
    -I removed jumper plug ch8010 on main power supply board and video signal returns, but this causes the picture to ghost or be very slow to refresh so I know this is not a permanent repair.
    The question is, with this information, is it the main power supply board that should be replaced? I have had a person (from ebay as I was pricing out the power supply board so I sent them a message) say it was the y sustain that is the problem.
    Any help in pointing me in the right direction is greatly appreciated.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sanyo DP 50747 50" plasma/Stopped working-No video
    Service manual.
    PlainBill
    • buntinre
      • Nov 2011
      Thank you for the link, that will come in handy.
      If you were a gamblin' man, what component would you suspect is at fault?
      • PlainBill
        • Feb 2009
        • 7034
        The unit between the chair and the keyboard.
        PlainBill
        • buntinre
          • Nov 2011
          Uh, yeah... thanks.
          I am just trying to fix this unit to get a few more years out of it. I am not an electronics or appliance tech, I know just enough to be dangerous, and I need real answers to get this thing working again or at least given a decent chance to be repaired before I recycle it. I found this site while searching for electronics parts and repairs and read a few posts and saw that it had an active member base and signed up to see if I could get the help I was searching for.
          I guess I got that answer, and that is to find another forum that can actually be of some help and not just deal out some dimwitted remarks from the old guy that sits around his house trolling a sub-rate forum with his bloated ego giving out crap to a new member. Thanks for the help, it pointed me in the right direction... far away from this place.
          • tw2005
            • Oct 2011
            • 6458
            Uh, yeah... thanks.
            I would not have taken PlainBill so personally. From my limited exposure to this forum he offers some pretty accurate and concise fault info. Pretty dry sense of humour. I think he's gold.
            Maybe instead of simply getting spoonfed, see what you can deduce yourself and post what you have found using the manual.
            • PlainBill
              • Feb 2009
              • 7034
              Uh, yeah... thanks.
              Ask yourself this question - If you were a mechanic and someone asks "I have a 2005 Ford F150 that won't start. If you were a gambling man, what would you say the problem is?" How would you respond?
              I'm not a professional mechanic, and wouldn't be caught dead driving a Ford F150, but off the top of my head I can come up with half a dozen possible causes ranging from the wrong key to no gas to a dead battery to a faulty computer to a frozen engine. The mere fact someone would ask such a question indicated they are a fool, and I don't tolerate fools gladly.
              The Samsung DP50747 (not DP 50747) is a similar situation. There are a number of possible causes, ranging from a bad solder joint to a bad panel. Like an automobile, there are a series of simple tests that may help identify the problem; those are probably outlined in the service manual. Suggesting any one part is folly.
              PlainBill
              • Pastortech
                • Apr 2012
                There are normally 2 2200UF capacitors c8323 and c8324 also with your high voltage low capacitance caps you have to replace 450v 22uf.There is probaly 10 caps total with the HEC made manufacture caps just change and this powersupply will be hgood to go.Symptons are normally click on voltages chck fine for 5 seconds then goes out.
                • mendota
                  • Aug 2012
                  • 5
                  • cascadia
                  PlainBill was right about needing to do some basic diagnostics. But the OP was right for calling him out on his bullshit.
                  in general, on a dead set, you turn first to the power supply board. immediately supposing it's a bad panel is a huge shot in the dark.
                  on that sanyo's power supply board, there were numerous capacitors, fuses, and diodes that would burn out in one way or another. it was bad enough to see corrosion on the fuse holders.
                  and if that didn't solve the problem, ics on the y-sus would burn out too.
                  i don't think those sanyo boards are "in print" anymore.
                  • nuryev
                    • Mar 2010
                    • 8
                    Hi
                    I am helping a friend with a Sanyo PD 50 who is having similar no picture no sound issues, TV switching off after a few seconds and burning smell.
                    We have replaced some swollen caps on the power supply board - now the power switch stays on when switched on, burning smell stopped.
                    Still no sound and no picture. Plugged in a dvd player - no change - no sound no picture.
                    Any advice how to proceed from here?
                    Thanks.
                    • nuryev
                      • Mar 2010
                      • 8
                      I am unable to access the Sanyo TV service manual from the link posted in a previous post in this thread. Has anyone managed to download a copy? If so could kindly forward a copy to me?
                      • Shane711
                        • Dec 2014
                        • 493
                        Here is the service manual
                        I am having problems with mine too. I am going to try Pastortech's solution.
                        • Shane711
                          • Dec 2014
                          • 493
                          Update, so I did what Pastortech said, I changed all the capacitors and yes, it did work. Tested the original caps and they don't look bad but now the power supply works so that says something. I guess the originals are not doing what they are suppose to do, very bad quality. Now the problem seems to be in the Y-SUS board so I had to order Caps for that. So the first thing I noticed with the TV was the X-SUS board was not working, replaced caps on that and then it was the power board, replaced almost all the caps on that and it started working and now it is the Y-SUS board. WOW, these caps are totally worthless. I am not sure what caps are the best but I been trying a few of the recommend caps and have not decided which ones I like the best yet. This site sure has helped me a lot. Whenever possible we need to make a data base of all this knowledge so I can download it into my brain, someday I guess that will be possible. They are saying they are working on that very thing, but then who wants a chip in their brain that is controlled by the government. I consider everyone on this web site my best friends because we all love electronics. Just so happy right now, having a good moment
                          I will post on here if I ever do get this TV working.
                          • canadaboy25
                            Sanyo DP5749 Plasma won't power up
                            by canadaboy25
                            Hey everyone,
                            I was given a Sanyo DP5749 Plasma that has failed. The symptom is the TV tries to start up and shuts back off about 3 seconds later. With the service manual I was able to determine that the TV is shutting down due to detecting a missing power rail. The 5V supply to the logic board is okay at startup but after a second it disappears. The TV shuts off shortly afterwards.
                            I traced the problem to a 3.3V enable signal from the D board to the power supply. This signal disappears for some reason which shuts a few power rails on the PSU off. The signal comes...
                            02-01-2021, 01:19 PM
                          • flat-earther
                            HP F4180 stopped working please help troubleshoot
                            by flat-earther
                            I was doing a large print job with my HP Deskjet F4180, and after about 50 pages the printer stopped in the middle of a page and the black ink light started flashing.
                            So I went to refill the black ink cartridge with a syringe, but found out it still had a lot of ink.
                            I tried to print a page again but every time it would print only a bit of the page and immediately stop with the black ink light flashing again.
                            I tried two other black ink cartridges, and the problem still endured, so I knew this problem had to be with the printer itself.
                            I ran HP Print and Scan...
                            05-11-2025, 02:21 AM
                          • ArMaaN376
                            Samsung PS51E550 Plasma TV
                            by ArMaaN376
                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                            Opened TV cover & observed foll
                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                            How to confirm Y -Buffer board...
                            06-19-2024, 04:05 AM
                          • jm1234
                            Panasonic plasma TX-P42ST50 - 6 blinks
                            by jm1234
                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                            I checked that board for any obvious faults...
                            05-22-2024, 06:59 AM
                          • KYBOSH
                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                            by KYBOSH
                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                            No picture but you hear the TV static (white noise) playing loud and clear.
                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                            But it seems they didn't get too far and just left it.
                            When I first took a look I was amazed at how pristine the inside looked.
                            Its as if the TV had been in a time capsule.
                            Caps looked like they were just pulled off the self.
                            Copper coils had no sign of corrosion on...
                            02-01-2023, 11:10 PM
