Technika 32-407B starting problems
  • riget
    • Sep 2011
    • 66
    Hi, got this tv that had starting problems, it would take several attempts to start, I found a cap leaking on the power board, so I changed 6 caps that I found on another site(can't find it now) said needed changing.
    It has been ok for a couple of months but now has starting problems again, this time the sound always starts but no picture, and you get a banging type noise, the hdmi logo will show but it will be dull, if it goes bright then the tv starts ok.
    I've found this pic of the power board on the net http://www.lcdtvparts.co.uk/index.ph...image&pID=1400
    The caps I changed are the six to the right, not the two at the top/right.
    If anyone can give me help with the faults I've described before I get the tv back, it would be great.
    Thanks.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Technika 32-407B starting problems
    Thanks.
    What brand and series of capacitors did you use?
    PlainBill
    • riget
      • Sep 2011
      • 66
      Hi, I'm not sure, I bought the best I could find on ebay, some were listed as panasonic but never had panasonic printed on them, I've just looked at my stock and I think some were called Suntan cd287, and some SD cd263
      Do you think it could be the same fault, I don't mind redoing them if these caps are not good enough.
      Thanks.
      • PlainBill
        • Feb 2009
        • 7034
        Thanks.
        It could be. There are several problems with "the best I could find on ebay". First, eBay is full of people selling counterfeit caps, reportedly only one eBay seller is reliable. Certainly I would be suspicious of a seller in Hong Kong who claimed to be selling Panasonic caps.
        Second, even buying genuine Panasonic caps is no guarantee that they will last. the vast majority of Panasonic (or any other brand) caps are unsuitable for this application. The caps must also be suitable for use in a SMPS power supply. For Panasonic, that means FM Fr, and possibly FC series
        PlainBill
        • riget
          • Sep 2011
          • 66
          Ok cheers PlainBill,
          Where would be best to get the caps from, I'm in uk, and what do I look for them to be suitable, I went for 105c low impedance, would buying from a shop be better/
          Thanks.
          • PlainBill
            • Feb 2009
            • 7034
            Thanks.
            Hopefully one of the many gentlemen (or even one of these who isn't) from the UK who frequent this site will offer suggestions. RS, Farnell, and Maplin? are some of the suppliers I recall being mentioned.
            PlainBill
            • riget
              • Sep 2011
              • 66
              cheers bill, I've ordered a full set and more from Farnell, mainly rubycon, I picked the best I could see, at least I'll know if it's the caps.
              Thanks.
              • PlainBill
                • Feb 2009
                • 7034
                Thanks.
                Statements like that give me the chills. There are half a dozen brands of caps that are reputed to be good. The most widely available are Panasonic, Rubycon, United Chemicon, and Nichicon. I happen to prefer Panasonic; I won't quibble with anyone who prefers others of these brands.
                In the Panasonic line FM, FR, and FC are suitable for use in a switch mode power supply, M, RB, and NHG are not. Presumably a similar situation exists in the Rubycon line.
                PlainBill
                • riget
                  • Sep 2011
                  • 66
                  I got one panasonic that's FM series, the rest are Rubycon ZL/ZLH/ZLG/ZLJ
                  Any idea if the ZL's are ok?
                  Thanks.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Thanks.
                    I should have done this earlier; my bad. The 'What Caps Should I Buy' thread in the 'Frequently Asked Questions' section has the answers. They don't list the ZLJ series, so I looked it up. At a quick glance, they are good.
                    PlainBill
                    • riget
                      • Sep 2011
                      • 66
                      cheers for your time Bill, I'll post back with the results in a day or two.
                      Thanks.
                        Rubycon ZL* series caps are very good. Almost too good for a TV power supply. Low ESR caps are important, but even a less than superb low ESR cap would probably be fine, and cost less too. Remember the originals were probably garbage. IMO, lifespan is more important than ultra low ESR in this kind of application.
                        • riget
                          • Sep 2011
                          • 66
                          Ok got the caps(very quick service from farnell) fitted them and still the same, so it seems the caps on the power board are not the problem, unless it's another that's not been changed.
                          I've just tried a few things and I'll post back later, as I need the tv to cool down before trying again.
                          Thanks.
                          • riget
                            • Sep 2011
                            • 66
                            Still no good, I thought I found something as I tried the scart connection instead of the hdmi and it worked, but it seems it was coincidence as it's back to the same problem.
                            What's happening is, when you turn on, the power light flashes for about 10 seconds, then the hdmi signal comes on the top right, then it should go bright and the picture and sound comes on, if you have no signal a yellow "hdmi no signal" comes in the centre, but you can see it's not bright enough, when you have a signal the sound comes on sometimes, other times it makes a noise like a tuned car engine, after several attempts to start it does eventually start, it then works fine till the next time you turn it on.
                            Thanks.
                            • riget
                              • Sep 2011
                              • 66
                              Got it sorted, I checked best I could all the connections, I resolder as many as possible, one smd cap looked like it could have been a cold joint,
                              anyway put it together and starts first time every time now.
                              • beemerbruser
                                • Aug 2012
                                • 13
                                • Ireland
                                HI,
                                I was reading your post about the issue you eventually solved. I have the same TV exhibiting the same symptoms. Can I ask you a couple of question?
                                1. In your final post, did you check all connections to all the boards & solder all connections on all the boards too or just the PSU?
                                2. Can you try to direct me to the SMD cap that you reckon could have been at fault too?
                                3. Was your PSU PSA-218-417-R? If so, which caps did you end up replacing?
                                Thanks a mil,
                                Steve
                                • riget
                                  • Sep 2011
                                  • 66
                                  This is going back a while, the best I remember is:
                                  1. Just the psu
                                  2. Sorry no, can't remember
                                  3. It was the one in the pic, replaced the caps down the right side,
                                  The original fault was the caps, but after the second fault and changing all the caps it was the same, I just went all over with my iron and it must have been a bad joint.
                                  Thanks.
                                  • beemerbruser
                                    • Aug 2012
                                    • 13
                                    • Ireland
                                    Thanks for the response. Yes, mine is the same as pic so I'll replace the same caps & go over the solder joints too. I'll post up here on how I get on as there may be others out there in the same boat.
                                    • mesersmith
                                      • Dec 2014
                                      • 35
                                      • România
                                      I have a problem with the same power board.
                                      My simptoms is that the board doesn't start at all.
                                      I look everywhere for a schematic of this, but no luck.
                                      Somebody on this forum knows something about this?
                                        • 31183
                                        power supplies that wont start - start by replacing startup capacitors.
                                        they are usually under 100uf
                                        • master3112
                                          Lenovo E15 Gen.3 NM-D481 No starting and charging via USB-C, The device starts only via the battery.
                                          by master3112
                                          I have a Lenovo E15 Gen.3, motherboard NM-D481 with a defective USB-C port. The device starts with battery. When connected to the USB-C power supply, it does not start or charge. 20V is present at the input of the UT5 (High voltage USB PD power switch), 0V at the output
                                          UT5 pin 3 (SNK_PS_EN) =0V
                                          RPT3 Pin1+2 LDO 3V3 present
                                          I suspect that the UT2 USB-C power controller is defective because the UT5 is only controlled by the UT2. However, the UT2 supplies on pin 33 (+LDO_3V3) which makes me wonder if it is defective after all. Unfortunately I don't have it here to test it.
                                          08-02-2025, 12:30 PM
                                        • Cornito
                                          Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                                          by Cornito
                                          Hello Team,
                                          I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                                          Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                                          Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                                          08-08-2024, 08:09 AM
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
                                        • tartuf
                                          FSP-350GLN(80) not booting mobo properly
                                          by tartuf
                                          Greetings
                                          My old 350W FSP-350GLN(80) PSU was working fine with my current computer for few years(and previously with few other computers as well). Nothing has changed in setup but since last few months I am getting problems while trying to boot PC.
                                          What happens, is that PSU starts and I can hear fans, both PSU, CPU, MOBO and GPU. I can also hear HDD scratching and normal starting sounds. But DVI monitor claims that there is "no signal". Moreover, neither USB mouse nor PS2 keyboard does flash leds like it should do upon boot.
                                          I have to turn PSU switch...
                                          12-23-2022, 10:54 AM
                                        • modtool
                                          Huawei Matebook D14 - NbB-WAH9Q - Shorted DrMOS MP86945A - DAH98NMB8B0
                                          by modtool
                                          Hi to all, this laptop came with no signs of life, no battery chargin and no start.
                                          I found that the main 19v rail was almost shorted, it measured around 7 Ohms , then searching better I found a shorted MP86945A DrMOS (between Drain and Source) that converts the 19 volts into the PCH core voltage...
                                          I was going to chuck the towel, but I had a new same DrMOS then decided to solder it in, then I connected the power jack and the system now powers almost on, all the voltages rise but the CPU core and VGFX core.
                                          Externally I only see that keyboard backlight lights up for 2 seconds,...
                                          09-29-2025, 08:05 AM
