Samsung LNS3241D - No picture, sound and backlight OK
    Four year old LCD TV first started showing problems with intermittent vertical lines across the entire screen; of varying number, width, and color. Now it turns on and stays on, but there is no picture, not even for a second; does not matter what source. Even the menu items do not display. The audio is fine and the backlight is on.
    I replaced a bulging 470uF, 25V cap.
    24VDC checked going to the inverter board.
    5.4, 12, and 13VDC look good going to the main board.
    LVDS cable and end connections appear okay. Contacts cleaned.
    Fuse F1 on the Tcon board is good.
    Is there any thing else, fairly easy to check, to narrow down the problem? I do have access to an O-scope from work, but do not have a lot of money to throw around. Any help would be greatly appreciated.
    Re: Samsung LNS3241D - No picture, sound and backlight OK
    The symptoms indicate a bad tcon. The intermittent vertical lines across the full screen indicate it's not a bad panel.
    PlainBill
      Fixed Samsung T-cons before, the fuse often blows, but the board is cheap anyway. You problem doesn't really sound like a fuse though.
        Thank You Bill.
        I did not know how to isolate the problem between the main board and Tcon. Is there a preferred place to purchase the Tcon board? Any places i should stay away from? Should i get the cable too?
        If it makes a difference, I did measure a few voltages on the LVDS connector on the main board side (ones that i could get to). All measured referenced to frame ground, VDC:
        AO1; 1.159
        A1-; 1.186
        GND; 0
        A2+; 1.235
        CLK-; 1.156
        GND; 0
        A3+; 1.167
        NC; 0
        NC; 0
        GND; 0
        PANEL_V; 5.36
        PANEL_V; 5.36
        PANEL_V; 5.36
        Thanks again.
          Thank You Bill.
          AO1; 1.159
          A1-; 1.186
          GND; 0
          A2+; 1.235
          CLK-; 1.156
          GND; 0
          A3+; 1.167
          NC; 0
          NC; 0
          GND; 0
          PANEL_V; 5.36
          PANEL_V; 5.36
          PANEL_V; 5.36
          Thanks again.
          Can you take a picture of the T-con and post it here?
            Thanks Tom, Attached is a pic of the Tcon board...
              I see one fuse, F1, on the board, to the right of the connector. Can you test that fuse?
                I did measure F1 Tom. Resistance is near zero with the power off. I measure 5VDC on both sides with power on. Thanks for the feedback.
                It may be interesting to note that the TV behaves exactly the same with the LVDS cable (I believe that is the cable to the T-con from the main board) connected or not.
                Please keep the suggestions coming...
                  On the righthand side, L33V. What voltage does that measure at?#
                  Since you are getting some voltages on the LVDS, I'm very tempted to say T-con.
                    Thanks, I'll check out L33V when i get home.
                      I just can not find an L33 anywhere. There are several V33's indicated and each measures 3.3VDC.
                      I did notice a POW_ON label near RP27 with a solder connection that i could probe. It only measures 0.005VDC. It is located just above the LVDS cable, above and to the left of F1. Any ideas that this is normal?
                        My error. I meant V33.
                        I'm drawing blanks. I say just replace the T-con and see if that fixes it.
                          Thank you for your assistance Tom. I do have one more observation and another question to make sure the problem is not with the main board.
                          In an earlier post i listed voltages from the LVDS cable with all cables connected. Last night i unplugged the LVDS cable on the main board to gain access to the rest of the pins on that cable, this is what i measured:
                          GND; -0.001
                          A1+; 1.028
                          A2-; 0.795
                          GND; 0
                          CLK+; 1.308
                          A3-; 1.220-1.226
                          GND; 0
                          PANEL_V; 3.528
                          GND; 0
                          GND; 0
                          PANEL_V; 5.37
                          PANEL_V; 5.37
                          Notice that one PANEL-V is lower than the other five. Could this be the problem or is this normal?
                            If the V33 point measures the same as that odd PANEL_V voltage, I'd say it's fine.
                              I just wanted to let you know that i have been following this thread with the same problem and i went ahead and bought a used t-con board and it fixed my problem.So i can say that i'm 99% sure a t-con board will fix your problem.
                                Yep, it was the T-con board. Replaced it and all is well again. Thanks everyone for the help.
                                  Hi guys,
                                  I have the same problem with the exact same model Samsung. Just wondering where you purchased new (or used) t-con board, price, and see if everything was still working. Much appreciate any suggestions! Thanks
                                    Originally posted by kammerer1 View Post
                                    Hi guys,
                                    eBay is a good source for boards.
                                      I'm having a similar problem and I was wondering if any of you can check out the thread I started and give me some advise. It would be appreciated.
                                      https://www.badcaps.net/forum/showth...d=1#post401162
                                        would TCON solve this problem I'm having same problem (no picture has sound) I recently ordered the caps (equivalent) installed them since i've noticed 2 were bulged and decided replace them all from clean slate...it was great for good 10 mins...until it came back how it was no picture and but sound with lines on the screen as illustrated on my pic..
