Vizio SV470XVT1A - Displays Red Pixels and Lines
  • 909
    • Oct 2011
    I have a Vizio SV470XVT1A and after about five minutes of being turned on it
    begins displaying red pixels and red lines on dark areas of what's being displayed on the screen. It does not matter what input is used, the red pixelation occurs whether you use hdmi, composite, or external antenna inputs.
    Other than the red pixel problem the TV works, ie; sharp picture, sound works, inputs all work, etc.
    I pulled the cover off the back and have checked all the connectors to make
    sure they were properly seated. I also inspected for bad caps and fuses and
    I am getting steady 24 and 5 voltages from power supply.
    From the various internet forums I have read its either the LVDS cables, the motherboard, the daughter board, the t-con board, the power inverter boards, the LCD screen, etc. I'd like to narrow it down a bit.
    Please keep in mind that I am not electronics technician, but a sophisticated wire wiggler and I do have a multimeter and I can do almost anything, as long as it's explained to me in English and not Technospeak.
    Any help is appreciated.
    909
  • texas1978
    • Nov 2011
    Re: Vizio SV470XVT1A - Displays Red Pixels and Lines
    Sounds like the LCD Video Processor over heated and not making a good contact, might wanna try the Coin and heat gun trick, on the Main board and LCD Video board. Would it be possible that I could get a copy of the Service Manual Please. texas1978@hotmail.com working on one with a problem not coming on, just when plugged in shows the orange vizio immediately and the 5.1 red dolby light comes on as well. No response from Power button. What happened is i tripped the breaker while it was running, tried to turn the breaker off to work on some outlets in my shop.
    thanks,
    Jeremy
    • Livermoron
      • Jan 2012
      • 7
      Other than the red pixel problem the TV works, ie; sharp picture, sound works, inputs all work, etc.909
      I have the same problem... has this been fixed? If yes, how? I am very hands on and cheap so I'll try anything myself first - just need to know what I am looking for!
      • brad2157
        Vizio E70-E3 Two white vertical lines
        by brad2157
        I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
        Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
        Replacement main board - Boots up fine, but starting...
        12-13-2021, 05:11 PM
      • x_orange90_x
        Vizio V585-J01 dancing lines and image doubling
        by x_orange90_x
        I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
        Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
        Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
        I swapped...
        06-12-2024, 07:57 AM
      • DrvLikHell
        Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
        by DrvLikHell
        Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
        The...
        02-05-2025, 01:44 AM
      • viking509
        vizio e65 e3 LED tv color vertical lines center tv only
        by viking509
        I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
        03-21-2023, 12:48 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
