Vizio VP50 HDTV20A power supply turns on then off
  • chouston
    • Oct 2011
    I have a Vizio VP50 HDTV20A which I recently got from a customer, he claimed it made a loud pop and stopped working, I hauled it off, opened it up, saw two blown 10v 3300mf caps, replaced them and plugged it back in. It clicked when I plugged it in then when i hit power it clicked once, then again, the orange led on front turned green but that was the end of it. I hooked up my meter to the back and watched the power outputs from the PS board jump up to the labeled voltage when I hit the power button, then immediately after the second click, drop back down to zero. No fuses are blown and I don't see any other bad caps anywhere... Any suggestions are greatly appreciated...
  • rayrod81
    • Oct 2010
    • 205
    Re: Vizio VP50 HDTV20A power supply turns on then off
    One of the sustain boards is most likely causing the power supply to shut down. These boards have a history of failing on this panel. Check all of the mosfets on the Y and X board for shorts.
    • chouston
      • Oct 2011
      I looked at both the X and Y boards and cannot find anything identified with a Q to identify a mosfet...
      • rayrod81
        • Oct 2010
        • 205
        There are at least 10 of them on each board if this is a Samsung panel. Post pictures of the back of the TV and the individual boards. Use manage attachments and do not post them inline. This could be an LG panel but that is a whole different animal. So post pictures and that should give us a better chance to help you.
        • chouston
          • Oct 2011
          Thanks, I will take pictures when I get home, however I am fairly sure it IS a LG panel. I read other posts of folks having similar problems and all their pictures looked different from the boards in my tv. Also, the smallest board inside, which contains 4 surface mounted lcds, has a LG chip on it. But again, I will post pictures when I get home.
          • rayrod81
            • Oct 2010
            • 205
            Sounds like the 50X4 panel in this one. If that is the case,then most likely the Y or Z sustain has a short on one of the IPMs causing the PS to shut down.
            • dejesus
              • 108
              • usa
              what is IPMs? i have the same tv with the same problem.
                IPMs are the large devices under the large heatsinks on each sustain board.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                  03-31-2024, 02:12 PM
                  07-01-2024, 06:34 AM
                • Super360
                  Vizio E701i-A3 Vizio logo flashing then turns off
                  by Super360
                  Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                  07-25-2024, 07:06 PM
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
