HDMI Signal interference
  • ScoutMaster
    • Oct 2011
    I am running HDMI over cat 5 to a panasonic 103" plasma. Distance is not that far (about 15m) and signal has been fine for months.
    Just recently, there is an intermittant,broken up, horizontal line rolling very fast up the screen that looks like analogue interference. It also runs through a HDMI switch but doen't appear on the secondary source. Any ideas?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: HDMI Signal interference
    Do you walk often over the cable, is it heavily creased somewhere, or have you dragged something heavy across the cable lately?
    • ScoutMaster
      • Oct 2011
      The cable is installed through a riser and from a rack. No chance of crush/creasing.
      • tedjar
        • Dec 2010
        • 51
        This is a situation that needs a "divide and conquer" troubleshooting technique...
        Lets consider the potential problems:
        1. The Source - Probably not since the 2nd display is OK
        2. The Switch - Could only one side be bad?
        3. The HDMI via Cat5 setup
        4. The Monitor
        Unless the monitor is mounted up somewhere inaccessible, I'd try to plug a DVD player or other HDMI source in direct via the same input in question. See where that goes, then you know you are chasing a monitor problem or a signal transmission one.
        I want to say ground loop, but not sure if that has any relevance since HDMI is digital. I do have fond memories of chasing hum bars running composite video to projectors over 150ft+ of RG6 though.
          Dear Santa.......
          On a more serious note, it sounds more like a problem with the TV than the signal - have you tried connecting something near to the TV?
          • supravit2000
            PS4 fat has inconsistent signal after HDMI replacement
            by supravit2000
            Hi, guys!
            I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
            My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
            12-19-2022, 08:08 PM
          • natiz
            Samsung UE65MU7003U / BN41-02568B - HDMI No Signal
            by natiz
            Following a power surge, the HDMI ports on a UE65MU7003U no longer work, no matter the port or the source - it shows No Signal.
            The other functions work well (eg Netflix app, etc.), its just the HDMI ports.
            Is the BN41-02568B board salvageable? Any leads before I open the heatsink cover? board replacement?...
            09-12-2024, 03:52 AM
          • Comp_Pro
            PS5 HDMI not outputting CK/DA Signal
            by Comp_Pro
            Hello all,
            I am trying to repair this PS5 which came in with a shorted HDMI encoder chip. This issue was not allowing the PS5 to boot and would only beep upon pressing the power button. This is the first time I've had this issue despite replacing many many HDMI ports. After installing the new chip as well as a new HDMI port the console now powers on and appears to be booting all the way but there is no video output. Looking at my HDMI tester all signals are present except for DCC Clock and DCC Data aka CK/DA on my particular tester. These two have direct connections to the encoder...
            10-09-2023, 01:38 PM
          • jimbofz
            harwa 42 lcd tv no hdmi signal output
            by jimbofz
            theres no precise model number on the rear cover boards labelled as below
            Hi just been given this lcd tv,
            ive not come across this make before
            there is no o/p from hdmi .its fine with scart .
            good pic for its age
            the main board is 782 L42W17-690B
            cant find much info on google
            to enter service menu .bring up a/v menu ,then 2580
            but cant move to next page ,for options
            (i was hoping ther may be an option to switch on/off hdmi/dvi)
            the reason for this , is when hdmi is selected it says: no dvi signal
            not: no hdmi...
            01-06-2022, 05:57 AM
          • AstutePauciloquent
            Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
            by AstutePauciloquent
            Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
            I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
            11-23-2023, 11:02 PM
