SOYO (mt-prtpt3208nb) lcd tv garbled screen
  • raymond
    Raymond
    • Oct 2010
    • 39
    Turns on nicely to a bright blue screen, menu works but seems a little snowy compared to the background blue. In all viewing modes though the image is incomplete as though it's not getting all of the necessary info ( similar to a computer screen set to the lowest possible settings with a limited color palette). Both the main and power boards look good with no bulging caps or burns. I haven't gotten down to t-con board yet. One reading on the PSU rail to the main board is 4.4 V(red wire) -seems odd.
    Any ideas as to where to start looking will be appreciated. Thanks.........Ray
    Re: SOYO (mt-prtpt3208nb) lcd tv garbled screen
    Have you tested the LDOs?
    Are those caps on the main board Panasonic? Seems surprising for such a cheap brand.
    • raymond
      Raymond
      • Oct 2010
      • 39
      What are LDOs?
      The biggest caps are purple Hermeis, the two mid sized ( center right) are brown Hermeis, the rest are black Hermeis.
        Originally posted by raymond
        What are LDOs?
        Ah yeah, so using the same vent, but a crap brand..
        Anyway, an LDO is a voltage regulator. Basically: Voltage comes in, less voltage goes out. It drops the voltage to a specific value e.g. 1.8V, 2.5V, 3.3V.
        I've highlighted some LDOs on the board. (Check the bottom too - there may be more.)
        With the TV powered on. Turn your multimeter to the 20V setting. Test each pin of each circled regulator, and note the voltages. Also note down the part number written on the device if you can make it out. Post your results.
        Then we can go from there and see if any regulators are bad. If they are, they can be replaced.
        • raymond
          Raymond
          • Oct 2010
          • 39
          OK, I will do that. Thank you
          I just now tried to turn it on from a cold start (unplugged state). The green led light came on but the screen didn't light up after 2 minutes. I tried again 3 times quickly, it lit up on the third try. What does that indicate?
          • raymond
            Raymond
            • Oct 2010
            • 39
            Here's a view of the screen. As mentioned in previous post it takes a few tries to start from a cold state but once it's been on it restarts as it should.
            • raymond
              Raymond
              • Oct 2010
              • 39
              LDOs on main board
              Start top left ....moving clockwize
              1117-3.3sj ( 0, 3.28, 5.15 )
              1117-1.8sj ( 0, 1.78, 5.15 )
              78do5al eetka1 ( 12.36, 0, 4.96 )
              1117-3.3sj ( 0, 3.28, 5.14 )
              1117-1.8sj ( 0, 1.78, 5.14 )
              78do5al eetka1 ( 12.37, 0, 4.99 )
                LDOs on main board
                All of those look good.
                Did you say the OSD/menus look the same?
                • raymond
                  Raymond
                  • Oct 2010
                  • 39
                  No, the menus look much better but not as crisp or solid as they should look.
                  Any other ideas......anyone ?
                    Well, as the problem is less severe on the menus, it's very likely not the T-con.
                    The easiest solution will be to replace the main board, if you can source a replacement.
                    • raymond
                      Raymond
                      • Oct 2010
                      • 39
                      Thanks for the info tom66 (your input is greatly appreciated)
                      The slow to start thing ... I can hear a slight whine from the PS when it's trying to start.
                      I wondering if it could be a bad cap without noticeable bulging.
                      • Dgtech
                        E. Technician
                        • Apr 2009
                        • 1462
                        • Steeler
                        I would change out the Tconn board. Just as a good guess.
                          Do you have an oscilloscope?
                          • raymond
                            Raymond
                            • Oct 2010
                            • 39
                            No, I don't have an oscilloscope....just a multimeter
                            • raymond
                              Raymond
                              • Oct 2010
                              • 39
                              It might come to that....I'm hoping it's an easier fix though.
                                Can you show a pic of the "almost clear" OSD?
                                Also, does the effect appear on black/dark scenes, and if so is the OSD affected?
                                • raymond
                                  Raymond
                                  • Oct 2010
                                  • 39
                                  The effect is constant in all light conditions. Here's 2 pics of the menu with and without a background image. The menu appears to get partially absorbed into the background.
                                    I'm trying to think - maybe the menu has a "transparency of OSD" option and that is what is causing the effects on the menu?
                                    • Dgtech
                                      E. Technician
                                      • Apr 2009
                                      • 1462
                                      • Steeler
                                      Since you are having the same problem with the OSD and the picture, It seems like the problem is either going to be in the Tconn board or the ribbon cables that go to and from it. Those items are common to both.
                                      • raymond
                                        Raymond
                                        • Oct 2010
                                        • 39
                                        Thank you tom66, you were right, it was set on halftone. The menu is now crisp and on top, nice to see. The screen image is still rough (as seen in this new pic), it has large pixel like squares flickering all over the screen. Would it be a good idea to replace those larger Hermei caps on both boards?
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
