SOYO (mt-prtpt3208nb) lcd tv garbled screen
    Re: SOYO (mt-prtpt3208nb) lcd tv garbled screen
    Originally posted by raymond
    Thank you tom66, you were right, it was set on halftone. The menu is now crisp and on top, nice to see. The screen image is still rough (as seen in this new pic), it has large pixel like squares flickering all over the screen. Would it be a good idea to replace those larger Hermei caps on both boards?
    It could be a good idea, but it's unlikely to be your problem.
    So it looks to be the main board as the OSD is unaffected when set correctly. Some video processing is going wrong. Exactly what, well that remains to be determined.
    At this point I would say replace the main board if you can source one, if not then a repair will have to be attempted.
    • mandypo
      • Sep 2012
      • Cuba
      Hi, I have a same problem with my 32Β¨ SOYO,I saved my TV for 2 years ,I bought a new board in USA and have the same proble, I check all voltages in power supply and the 5V is slightly high (in PCB marked 5V) 5.15v , I donΒ΄t have squematic or Service Manual, but I check all cap, at first sight all well, service manual or squematic are welcome , I have osciloscope, multimeter and counter , some help, maybe the new card have de same problem, maybe is the power supply I not sure right now , thanks
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
