VIZIO VO42L inverter ribbon removal
  • windfreik
    • Sep 2011
    • 18
    Help, How to remove the inverter ribbon on this inverter master board..?????? I have removed many ribbons on laptops, iphones, etc, but this one i have never seen. DOes it have a flip up latch like others? or just pull hard??/
    Brett
  • salvador437
    • Oct 2010
    • 9
    Re: VIZIO VO42L inverter ribbon removal
    that is a pull hard one.
    • windfreik
      • Sep 2011
      • 18
      Thanks salvador437! It just looks like the plastic top on it comes off somehow and I am afraid of pulling too hard(I pulled fairly hard to start with)! When I get the board fixed I wonder if it will be just as hard to put the ribbon back in?
      • satcruiser
        • Sep 2016
        • usa
        Which side to pull and which direction? Up or back?
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Grab the blue on the inverter side and firmly pull straight out
          • x_orange90_x
            by x_orange90_x
            01-29-2025, 09:24 PM
          • zesko
            xps 9520 ribbon cable
            by zesko
            I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
            There is 2 models, idk which one is needed on my laptop.
            0xkvng
            00vpr2
            Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
            Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
            thanks...
            10-23-2025, 05:03 PM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
