Vizio GV47L - I have sound and backlight, but no picture
  • richiewoo
    • Jul 2011
    • 11
    Hi!
    I have a Vizio GV47L FHDTV20A.
    It powers on fine, all the buttons on the fron seem to work, but there's no picture. The backlight is on and looks good and everything seems fine visually. There's just no picture.
    The video signal isn't making it to the screen. The menu doesn't come up on the screen, etc.
    It works, just nothing on the screen. So, what do you think? I think I've narrowed it down to two boards... either the large main board or the smaller LCD control board. On visual inspection they all look fine. I don't see anything out of the ordinary. I continuity tested every fuse I could find.
    Any ideas?
    Thanks in advance!
  • rmoody
    Learning Member
    • Jul 2011
    • 262
    Re: Vizio GV47L - I have sound and backlight, but no picture
    more than likely it's the inverter(s). Some have 1, some have 2
    • PlainBill
      • Feb 2009
      • 7034
      Good day celebrating the holiday? Reread the third line of the first post.
      richiewoo, I'd order the tcon; they are available for a lot less money and most main board failures also lose sound.
      PlainBill
      • stevekasian
        Old N00b
        • Dec 2010
        • 182
        • USA - West Side!
        Tri-State Module has a possible match for $18.95 +shipping:
        http://www.tristatemodule.com/p-3136...lcd-logic.aspx
        Searching around and cross-referencing some of these numbers I'm finding, it appears you may have your work cut out for you:
        You should definitely do a thorough job of searching and cross-referencing part numbers & model numbers to make sure you're buying the right board, as I am finding certain conflicting info on different sites. Looks like someone with dyslexia may have been entering numbers into their retail database and others may have picked up on the erroneous #s.
        Look up images of the board and look for number matches with version numbers/codes printed on the PCB, etc. Use the images to narrow down the ACTUAL board # you're looking for, then begin searching the best price.
        Do your due dilligence, as you don't want to end up buying the wrong board!
        SK
        • richiewoo
          • Jul 2011
          • 11
          I appreciate all your responses!
          I just wanted to make sure I was heading in the right direction.
          I narrowed it down to either the main or LCD controller boards, but like you said, Bill, I probably wouldn't have sound if it was the main...
          I'll pull that board and ensure I get all the numbers off of it. It's no fun ordering the wrong one!
          I wish there was a bad part that I could actually see! ! Probably a micro cap went. After I pull that board, I'll give it a real good once over with my meter.
          Thanks!!
          ~Woo~
          • stevekasian
            Old N00b
            • Dec 2010
            • 182
            • USA - West Side!
            There are most likely one or more SMD fuses on that board. They'll be labeled with F #s. Usually located near where the LVDS cable plugs in. Others here can help you further on that.
              One thing you can try. Disconnect the LVDS cable just slightly [not fully] and fiddle with the connection, this will stimulate the pins on the connector and should cause some random patterns to appear. If any lines or pixels appear, the t-con is probably good and the main board is probably at fault.
              • rmoody
                Learning Member
                • Jul 2011
                • 262
                PlainBill
                haha, no celebrating, just human error.
                • richiewoo
                  • Jul 2011
                  • 11
                  UPDATE _ FIXED Re: Vizio GV47L - I have sound and backlight, but no picture
                  Hi guys!
                  Sorry for the delay with getting back to this post.
                  It was the TCON board.
                  I was able to find one on eBay for $15 shipped. I replaced it and she fired right up!
                  I love it when it's cheap!
                  Thanks again for all your help, I really appreciate it!
                  • Ierwin
                    by Ierwin
                    05-13-2025, 03:31 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • triplefour
                    by triplefour
                    09-13-2023, 10:43 PM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Mgiffune
                    by Mgiffune
                    I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                    I ordered a supposedly β€˜new' Tcon board this time, and
                    06-09-2024, 10:28 AM
