Can anyone point me to the datasheet?
CXA3809M Data sheet
Tags: None
Re: CXA3809M Data sheet
Looked everywhere and no luck....sorry. I did come across an electronics site that stated that the particular ic is pretty scarce. So that explains not finding the datasheet. Hope you have better luck than I did but I put about 2 hours into it to no avail.Comment
Me too.Mann-Made Global Warming.
- Dr Seuss
Here is an e-mail response I received from Jameco Electronics.
Good afternoon.
Unfortunately, we do not carry or offer this CXA3809A IC. I have taken the liberty to find distributors and datasheets but no one carries the IC nor data sheets are available for this IC. Seems like this is an exclusive IC that SONY carries for their own devices. You may have to go direct to SONY to purchase and get the datasheet as well.
Thank you for your inquiry with Jameco Electronics.
Regards.
Jaime M.
Copy Writer / Technical Writer / Technical Support
Jameco Electronics
Sorry Village Electronics.....I tried.Comment
As a follow up ask for an email phone number at Sony.
Just figuring out where to go at Sony would be a nightmare all by itself.
- Dr Seuss
I'm also assuming Sony would most likely (like most Electronics Manufacturers) tell VE that they do not sell their electronic components directly to customers.....been there, done that.Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by flibidyI have here a Magnum IA.100 which belongs to my parents.
The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
What Ive done........8 Photos-
01-01-2025, 01:26 PM -
This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....09-12-2024, 02:00 PM
Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
The boards are powered by a ground referenced... -
by Joe24Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
I've been over the board looking for... - Loading...
