Generic (Technika ) 32" LCD TV Fault
  • 90Ninety
    • Aug 2011
    • 86
    • UK Mains Voltage 240V 50 Hz
    Ok
    I had brought a faulty TV for very cheap , knowing it was faulty , in hope that I could repair it .
    Symptoms:
    Upon initial inspection , I noticed there is impact damage to the top corner casing , though the screen seems intact and clean. The TV once plugged in shows a standby red light , I can press the power button and the TV then makes a short humming along with a short buzz which lasts for 5-7 seconds . The TV LCD backlight appears to then come on , though the screeen remains plain black for approximately 1 minuite .
    after a minute or so various thin cloured lines start slowly appearing , until It finally settles like this :http://img268.*************/img268/9902/dsc1042zm.jpg
    I then dismantled everything , and Visually checked all the Caps , connectors and soldering Everything looked fine . I double checked and re-plugged the ribbon connectors on the T-Con board . I tried to turn on TV after checking over , though it is still the same
    On a plus note , apart from the LCD panel and housing all replacement parts are available on Ebay . I am currently watching a replacement inverter board and T-con board on Ebay . Seems like this TV uses a TCON board that is also used in Sony models
    Judging by the damage on the TV housing , I have a slight hunch it may be a faulty panel , though I hope not
    I have searched the internet and people with simmilar problems have mentioned the T-COn board and Cap replacements as possible solutions . What do you thing could be the fault with this TV, how shall I rectify it? I would like to be certain
    Look foreward to hear from you all
    Peace
  • gorr35
    • Nov 2010
    • 127
    Re: Generic (Technika ) 32" LCD TV Fault
    I have the same problem with my Proview PA-40JK1A....except the symptoms on mine are reversed. Started out with thin vertical lines and buzzing sound and now just a black screen and no power light....weird. Me and a friend got mine going for about 3 months by using the heat gun trick but it's down again but even worse now. I hope someone can help you with yours but my post is so old, nobody looks at it anymore.
    • 90Ninety
      • Aug 2011
      • 86
      @ gorr35
      On which board did you use the heatgun ?
      Have you tried replacing the faulty part?
      • gorr35
        • Nov 2010
        • 127
        Originally posted by 90Ninety
        @ gorr35
        The heat gun was used on the power supply, the mainboard and the tuner board. A hair dryer will work also. I will replace the faulty part when I figure out which one it is. My first thought was the T-Con board....until the TV started going out all together.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Re: Generic (Technika ) 32" LCD TV Fault, Black screen with colured vertical lines
          The panel is good, otherwise it would have exhibited the issue from the very start. You have a Tcon or main board failure. gorr35's suggestion to use a heat gun on the large ICs is good, try it.
          A working TV? How boring!
          • 90Ninety
            • Aug 2011
            • 86
            A little piece of advise my father gave me: If it drives, flies, floats, or fucks, it will cause you problems.
            LMAO
            Well I am not sure of the background of the TV , though as mentioned above the TV casing/house/shell is cracked in the corner . So it looks like it has been dropped at some point, though I am unsure if this caused the damage . I brought it faulty on purpose btw . You may be right though , the LCD panel seems clean and intact . I've ordered a T-con board replacement anyway , I will let you know if that fixes the fault
            Which parts are the IC's ? I presume they are the Square chip's on the boards no?
            I didn't want to start working without knowing which parts to heat up with the gun
            On a side note I have re-flowed a ps3 using a heat- gun , worked like a charm afterwards
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Yes. IC stands for Integrated Circuit btw.
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • netgearnetgear
                TCL 43S423 TCON OR PANEL FAULTY???
                by netgearnetgear
                Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                08-20-2025, 06:04 PM
