Hello there,
i have a graphics card with 4 caps blown away. All of them are Sacon FZ.
There are two types, and the datasheet is not very informative. What i have found out is this:
Fist one:
6,3V; 1500uF; Diameter 10mm; Length 12,5mm; Tan 0,24, Leakage 283,5 µA, Ripple 1800; Impedanz 0,022 Ohm
Second:
16V; 470uF; Diameter 8mm; Length 12mm; Tan 0,16, Leakage 225,6 µA, Ripple 1150; Impedanz 0,036 Ohm
I know that caps should be used at right Voltage, because they are most effective at 75% of their nominal Voltage and a too high nominal V would degrease lifetime. The more the diameter, the longer they last, the lower is their ESR (theoretically). But have i take care of the "tan" which is a thing i do not understand, and also i don't know if a leakage should be high or low, same question for impedance.
In my search i found three caps which seem to be the correct ones, could you please comment this?
Replacement for the 1500uF:
RUBYCON 6.3ZL1500MEFC10X20
PANASONIC EEUFK0J152
PANASONIC EEUFM0J152
Replacement for the 470uF:
Panasonic EEUFM0J152
RUBYCON 16YXF470MEFC10X12.5
RUBYCON 16ZLH470MEFC8X11.5
RUBYCON 16ZLJ470M8X11.5
Thank you!
Thomas
Fist one:
Second:
Thank you!
Thomas
