Hi all.
I'm working with a LG 42X3 panel fitted in a Fujitsu plasma. Problem was a shorted IPM on the Y-SUS. This one is using the STK795-811A (YPPD-J014C).
It was replaced successfully.
When powering it up, I read all operating voltages OK. I also monitor the power consumption of the set and in a few seconds the power meter shows 635W (!!!) when I as quick as I could, disconnected the set from mains.
The power meter is reliable, it's no problem in measuring, since this power meter shows both appearent power and effective power simultaneously, together with power factor.
First throught was that Z-SUS had a failure, so I carefully measured across the IPM and that measures fine. But, when Z-SUS is disconnected, the power meter shows only 100W, which should be quite normal.
So, my question is, is it big chances that the Z-SUS IPM is bad anyways?
