TV problem
+ More Options
Posts
  • Tom41
    • Oct 2005
    • 336
    • England
    TV problem
    My big TV, after many years of service, has finally given up on me. When I push the power button, nothing comes on the screen, the power LED lights dimly and there is a LOUD buzz from the loudspeaker. The buzzing continues until I turn the power off again - it sounds rather like a motorcycle revving up and down.
    Power on - buzzing starts, rising to a pitch
    Power off - buzzing lowers in pitch and finally stops.
    Sometimes if I keep turning the power off and on, it will eventually start up. But it's a chance I don't want to take when turning it on to watch programmes at 6am!
    It sounds to me like something is energising and then cutting out straight away, causing the normal 'pop' from the loudspeaker to turn into a loud buzz. Perhaps the caps have bulged/burst/dried out, but I haven't opened it up to look yet.
    I do have a spare TV (thankfully), but that's also got a problem - the color level keeps changing, and sometimes alters if I touch the front panel buttons! Loose connection somewhere?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • Rainbow
    • Aug 2005
    • 1371
    Re: TV problem
    It looks like some caps in the power supply dried out.
    • Decade
      • Dec 2005
      • 37
      Re: TV problem
      As Rainbow stated dried out caps could cause this but check for any cold solder joint around the HV transformer or in the psu, could be lots of things.
      What brand model?
      • arneson
        • Sep 2005
        • 1267
        Re: TV problem
        Had a bad thunderstorm recently?
        That kind of problem is often found in the vicinity of the power cord.
        Diodes are very much suspect and vreg chip.
        Jim
        • chipper
          • Aug 2008
          • 95
          Re: TV problem
          Usually , bad capacitors would not allow the transformer to power up at all , and a pause would be followed by a complete shutdown (refusal to run). If the transformer is worn out , you will hear a high pitched screaming sound , that is audible in the speakers because of the transformer short circuit in the winding.
          This is not always the case , because a very badly blown or open capacitor can cause the transformer to act like it is not powering up in extreme cases. I have even had an older amplifier cause the exact same circumstances when it had been heating up during operation so much that it had warped the circuit board it was mounted to. Because the board was curved , heat eventually caused the dried out solder on 1 corner to loosen and eventually become (uncontacted by the base connectors). When the unit cooled , it worked , but went off within half an hour. When I opened it , I saw the corner (loose) , so I powered on the unit after cooling and pushed the transformer back into it's leg slot with a piece of thin wood. The unit kept working , but required a large solder and resetting job to make it stay flat on the board and connected.
          This was all because the 1 leg solder was grounding the audio power ic's in the traces.
          Once done the transformer worked with volume , but still did make a slight whistling or whining sound , without speaker interference below full volume. In this case , it meant that the transformer was near it's end of it's lifespan and needed replacing.
          So , in other words , when you hear whistling coming from a transformer , it is usually shot , and replacing it will remove the sound completely. The capacitors only store voltages provided by the transformer for use in the circuits.
          • chipper
            • Aug 2008
            • 95
            Re: TV problem
            The color changings from the front buttons are the flyback settings being sensitive to any input voltages or amperages. You need to check the flyback setting screws on the side of the tv where the red wire with the tube boot on it goes into. If the tv allows put a screwdriver in the black setting knobs and turn them to set base colors.
            Make sure that you set the brightness to as high as the set will allow and still be visible before you set the colors in the flyback control to lower the color settings. This will cool the flyback down and make it less sensitive , but it is on the way out if it wasn't badly maladjusted in the first place. Contrast should be used to sharpen the picture , not brighten it after everything is set low. The high settings are supposed to be on the controls only , not by setting the flyback high and the set high. It leads to whistling or humming and heat sensitivities. (low current overload)
            • chipper
              • Aug 2008
              • 95
              Re: TV problem
              The standard procedure for setting colors , on any tv , including laser or color wheel sets , is to set the brightest color first , then the other 2 as they compare for brightness. This is according to service manual specifications , to ensure highest brightness without overload to flyback. (less heat - longer life)
              The same thing is applied to brightness , it should be set high so that the flyback has less current flowing to each color production circuit before setting color density.
              All tv and remote controls : tint / contrast / color / sharpness and alike are for adjustment only , and should not be used to increase the base color density , but to decrease any over brightness or color density overloads at different settings.
              Controls are for turning the settings down , not up in general.
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • Gibon378
                Problem with stopping audio and video for no reason
                by Gibon378
                PC Specs:
                • CPU: Ryzen 5 1600
                • GPU: GTX 1080 Palit JetStream
                • MOBO: ASRock ab350 PRO4
                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                • PSU: XFX 650W (don't remember what model)
                • OS SSD: ADATA SP920
                • OS: Windows 10 21H2
                Problem description:
                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                11-19-2022, 09:41 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • SDNarcia
                Dell 15R-5521 keyboard problem (KBC?)
                by SDNarcia
                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                As additional information,...
                07-20-2024, 10:47 PM
