Sony KDL-46V5100
  • kvanburen
    • Jul 2011
    Sony KDL-46V5100
    I have a Sony kdl-46v5100 that doesn't show any picture or any backlight. The only thing it does is the relay clicks when power button is pushed and the standby light gives 2 flashes. I am thinking it is the power supply board but i wasn't sure what to look for on it that would lead to suspecting it. I ordered one off ebay to test it. If it isn't the power supply board what board would suggest it being??
    -Thanks
  • Village Electronics
    OldPro
    • 118
    Re: Sony KDL-46V5100
    -Thanks
    IP2 board
    • kvanburen
      • Jul 2011
      ok thats the one we ordered. Is it just a swap and go? Or are there error codes that need to be cleared? I am kind of new to this whole TV repair thing.
      • dxucam
        • Nov 2022
        • 14
        I have the same model (Sony KDL-46V5100), same symptoms; click on power cycle, no video, no sound, and no backlight.
        The logic board does appear to get the standby voltage, as evidence by a red flash in the optical audio input port.
        I read somewhere that this was likely the main logic board, rather than the power supply board (IP2?). Logic board model number 1-879-239-13 / A1660699A
        Any suggestions? Thanks!
          • 12328
          • U.S.
          so whats the symptom, steady clicking, one click, two clicks?
            • 12328
            • U.S.
            do you have any indicator light on the front? can you post some good clear straight on pictures of each board and one of the whole back as to see how everything is connected.
              • 12328
              • U.S.
              do you have a multimeter for some simple voltage testing.
              • dxucam
                • Nov 2022
                • 14
                Thanks for the response. There is a single click when the TV is turned on or off; once on there is no sound of any kind, nor any picture.
                When the unit is off there is no standby light that I can see. Once turned on, there is a green LED light along the bottom of the frame towards the right of the unit as you face the screen.
                I do have a multimeter to check things; was hoping to test the voltage arriving at the board from the power board, as well as the power going to the LCD controller (T-Con?), to verify where the issue is. But I'm not sure where to test - in a hole in the wiring harnesses coming into and going out of the logic board?
                I've attached a picture of the whole thing (I think); I can send close-ups of the boards but there isn't good light in the room I have the unit in, so it'll be a minute. I will say that they look clean, no visible scorching or capacitor bulging/leaking.
                • dxucam
                  • Nov 2022
                  • 14
                  Images of the power and logic boards...
                  • redwire
                    • 3912
                    I don't know this set- but it appears the relay RY6000 gets 3.3V standby power (for the clunk) which then switches primary power to the PFC and main 12V SMPS.
                    So I would check if the 12V rail is coming up, say at CN6150, measure and list all voltages on that connector and CN6154 too.
                    Service manual
                    • dxucam
                      • Nov 2022
                      • 14
                      Service manual
                      CN6150:
                      1 - 0v
                      2 - 2.9v
                      3 - 4.0v
                      4 - ~12v decaying; starts at a high value and drifts lower.
                      5 - ~12v decaying
                      6-13 - 0v
                      CN6151:
                      1 - 12v
                      2 - 12v
                      3 - 0v
                      4- 0v
                      CN6154:
                      1-4 - 0v
                      5 - 3.5v
                      Is the decaying voltage a sign of a leaky capacitor?
                        • 12328
                        • U.S.
                        could be, check the 4 electrolytic caps closest to cn6150 or you might want to just change them out, they're usually the ones that start acting up first, I would check ALL solder joints on powerboard, make sure tv has been unplugged for a few hours because of the high voltage the big cap can hold around 400 volts which can be LETHAL, be careful where you touch the board with your hands, just the edges is best, you can check the voltage left in the big cap with multimeter set to vdc, probe on each leg to make sure it's drained, depending on type of meter you have if it's not auto-ranging then set it to 400 or closest, then can go to 200 or 20 til you get a reading, because it can be tricky, if the cap has 400 volts in it and It's tested on the 20 volt setting it won't read the voltage because its out of range, will just read ol or l or such, example of bad solder joints there, look them over closely, touch up any suspect looking joints, check closely the joints on transformers and the components located on heatsinks BUT check ALL joints, careful not to bridge any, can practice soldering/de-soldering on an old scrap circuit board if not use to it: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
                        • dxucam
                          • Nov 2022
                          • 14
                          Thanks for the info, I'll look for any obvious damage but probably won't be swapping any capacitors,
                          To test the rails I unclipped the ribbon connectors, breaking the connection to the logic board. Given that, do the readings I got convince you that it is the power board (I2P) and *not* the logic board? Or does disconnecting the cable change what I should expect?
                          • dxucam
                            • Nov 2022
                            • 14
                            To see what effect disconnecting the cable might have had, I left it installed and checked the voltages on the solder paths leading the destination rail on the logic board coming *from* CN6150 - labelled CN1003, circled in the picture - and indeed got different results.
                            1 - 3.9v
                            2 - 2.8v
                            3 - 3.9v
                            4 - 18v (steady)
                            5 - 18v
                            6-10 - 0v
                            11 - 15v
                            12 - 15v
                            13 - 15v
                              • 12328
                              • U.S.
                              can you label those? like power_on xxx, ac_det xxx, so we know what pin is what.
                              • dxucam
                                • Nov 2022
                                • 14
                                They're all labelled correctly in the image that @redwire posted: https://www.badcaps.net/forum/attach...3&d=1668048460
                                  • 12328
                                  • U.S.
                                  some of those voltages seem a little high compared to the picture but I think they are ok, now try this little test that I used on my old kdl, with tv unplugged from power, unhook cable from powerboard to mainboard leave it off, plug power cord back in, see if theres anything on the display.
                                  • dxucam
                                    • Nov 2022
                                    • 14
                                    Probably I just have a crap multimeter.
                                    I tried the test, didn't see anything on the screen - but would have missed anything subtle, as there is daylight in the room. Also, with the cable disconnected the TV doesn't turn on (click, green LED), so I'm not surprised.
                                    • lotas
                                      • Jan 2016
                                      • 4852
                                      • Russia
                                      First check all the fuses on the board, Sony has a lot of them with the numbers "Fxxxx".
                                      • dxucam
                                        • Nov 2022
                                        • 14
                                        Thanks, will do... though my current multimeter doesn't have a 'continuity' test setting.
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • Destroyer-Br
                                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                          by Destroyer-Br
                                          I'm working on an Acer Nitro 5 unit with the following specs:
                                          • Motherboard: LA-J871P Rev: 1B
                                          • Model: Acer AN515-55-59MT
                                          • S/N: NHQ7JAL00403906A973400
                                          • SNID: 03902728734
                                          Initial Issue
                                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                          04-17-2025, 08:18 PM
                                        • gersrt
                                          Ordered Wrong TCON Board For Sony TV, Can I flash Epprom
                                          by gersrt
                                          HI
                                          Made a mistake and ordered the wrong TCON board to replace in my KDL-46HX823, the board I ordered was Sony PLY 1-883-893-11 which is sort of correct.
                                          But later realized this board is used in 4 or 5 models, any way the one i got sent was for KDL-55HX820.
                                          Physically these boards are identical, everything on the board is the same. I havent put this board into the TV yet, but am I right in saying all i would have to do is copy the Epprom from my faulty board and transfere it on to the new board, or is there still something else that may stop this working....
                                          01-27-2021, 05:49 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
