hi i have a plasma tv that will not turn on,it was ok one day then the screen turned red and the tv switched off,when i try to turn it on i can hear it clicking on green then back to red,i have uploaded some pics and realy could do with some help,the caps seem fine Thankyou in advance
LG 42PC1D plasma tv
Re: LG 42PC1D plasma tv
If anything can be blamed for the decline of the English language, Twitter and texting are going to vie for first place. Readability is greatly enhanced by proepr spelling, as well as proper use of punctuation and capitalization. Remember, if we have problems figuring out what you are saying, we can't (or won't) help solve your problem.hi i have a plasma tv that will not turn on,it was ok one day then the screen turned red and the tv switched off,when i try to turn it on i can hear it clicking on green then back to red,i have uploaded some pics and realy could do with some help,the caps seem fine Thankyou in advance
Facing the back of the TV, the Y-Sustain is on the left, the Z-sustain on the right. The usual process for identifying the cause of this problem is to unplug the large (power) cable to the Z-sustain and try to turn the TV on. If it now turns on, the Z-sustain is probably the problem. Turn it off, wait a few minutes, reconnect the cable, and disconnect the similar cable from the Y-Sustain. Again, try to turn it on. If it now turns on, the Y-Sustain is probably the problem. Again, turn it off, wait a few minutes, and disconnect the Z-sustain again. Now try to turn it on again.
If it turns on and stays on when the Y-sustain is disconnected, the Y-Sustain is probably the problem.
If it turns on and stays on when the Z-sustain is disconnected, the Z-Sustain is probably the problem.
If it turns on and stays on ONLY when both the Y-sustain and Z-sustain are disconnected, the power supply probably is the problem.
If it turns on and stays on when either the Y-sustain or Z-sustain is disconnected, but not when both are connected, the power supply almost certainly is the problem.
PlainBillLast edited by PlainBill; 07-12-2011, 11:48 AM.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
(This is going to hurt). it suonds like the z broad is good anduthe y boadr is bad.youwwil ave to place tye y bord and adjustit.oar yewc oud try 2 rear it yerselfr
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
obviously oenfothose two statemsis incorrect.
PlainBill.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
And now both are correct.
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
by wwwI am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....-
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
Hi.
I kindly ask you to help me solve the problem.
Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
The board turns on, there is no image.
Read more. When the power supply is connected, the front panel indicators light up briefly.
When you press the power button, the button indicator lights up. The board works
there is no image, there is no matrix initialization, there is no image on HDMI.
When turned on, the fans do not spin, but when they warm up they start spinning.
When you turn off the button, the fans spin up to full speed for a short... -
by Egidio85good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
This defect happens continuously, hearing the classic click of the relay every time.
Power supply board BN44-00636B
disconnecting the mains and lamps from the power board always causes the same problem.
Is it normal that without anything connected this power supply turns on and off cyclically?
any suggestions on what to check?
thanks in advance
- Loading...
