Magnavox 42mf231d/37 plasma problems
  • v8focus1
    • Jul 2011
    Hello all, I've been reading through some of your solutions for the Magnavox plasma tvs (model 42mf231d) but my problem does not seem to be like any of the others. I bought the tv from a friend a year and a half ago. It hardly gets used. The other night I was watching tv and the screen went pixelated and then dark. Audio is perfect and the occasional multicolored pixel type blotches in the screen flicker. It never shuts off, the blue light stays on. I've checked for the bad capacitors like others, I've checked for bad fuses, I did the voltage tests and they all are right on the money with the specs on the sticker inside. I've checked connectors, looked and smelled for anything burnt but have come up empty. Is it possible the screen has gone bad? Thanks for your input!
    Ian
    • Jul 2011
    • 6070
    Re: Magnavox 42mf231d/37 plasma problems
    How old is the set is there a date stamp on it
    If has the crappy caps in it and more than few years old maybe you should recap it
    make sure you LOOK at the bottom of the caps to if they pop from there as well as the top of the cap
    If you do not see any thing then you need a dvm and start looking open or short parts
    I am sure there are people on this forum that would be glad to help
    • rayrod81
      • Oct 2010
      • 205
      Bad Y-main and buffer boards. Common failure on this tv.
      • v8focus1
        • Jul 2011
        The set was mfg in july of 2006. Parts are getting in short supply for these because of all the problems. Is anyone repairing these boards? Does anyone know the part that's failing and causing the problem to begin with so it can be delt with before it fails again?
        • PlainBill
          • Feb 2009
          • 7034
          There is an extensive discussion of the TVs built around this plasma panel on the Coppell TV repair blog. The pertinent information starts in roughly March, 2010.
          This same TV has been discussed in other threads. A simple search would have found the information.
          In a nutshell, the buffer ICs degrade over time. Eventually one will short. When that happens it causes a transistor in the Y-sustain to short, and possibly also damages the other buffer.
          The expensive repair is to replace both buffers and the Y-sustain. The inexpensive repair is to replace all buffer ICs on both buffers, as well as the shorted transistor on the Y-sustain, and test the Y-sustain for other problems. The last time I checked, rebuilt boards are available on eBay. In any case, with 42" plasma TVs available for under $500, spending over $200 to repair a 5 year old set doesn't make sense.
          PlainBill
          • v8focus1
            • Jul 2011
            I read about other problems but didnt see anything involving the light show that I had going on. I agree with not spending too much on this old of a unit especially with all the problems they have. Next issuse is what to do with this non working tv? Seems like a waste to take it for scrap but pointless to try to ship it. Thanks for your help!
            • survivalbloke
              Macbook A2289 - backlight problems - have checked a lot already - out of ideas
              by survivalbloke
              This is A2289, board 820-01987-A. It came in with the screen not working. We could not see any image on the screen, so we ruled out a backlight issue and instead replaced the panel. The display now comes up, but no backlight.
              I didn't see any signs of liquid damage, but there was some odd looking spots around U8400. F8400 has voltage on either side of it, and I have 5v present on R8444 and R8445. I did not have 3.2v at R8442 so I figured U8400 was bad, and I replaced it. After replacement, a brief probe to R8442 showed 3.2v so I assumed I had fixed the device. After reassembly however,...
              09-12-2023, 11:44 AM
            • jean luc ferre
              laptop hp g72 b52sf screen problems
              by jean luc ferre
              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
              06-07-2025, 03:27 PM
            • PlasMatt
              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
              by PlasMatt
              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
              09-20-2025, 06:50 PM
            • tonybig10
              Magnavox MDR515H/F7 And Magnavox MDR537H/F7
              by tonybig10
              Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
              the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
              03-07-2025, 01:03 PM
            • Hondaman
              USB problems?
              by Hondaman
              Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
              (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
              I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
              08-12-2024, 03:26 PM
